Ergebnis 1 bis 10 von 12
Thema: LCD-Ansteuerung funktioniert nicht
Baum-Darstellung
    ich versuche gerade eine eigene LCD-Ansteuerung ohne Lib hinzukriegen, leider wird auf dem Display nicht angezeigt...
    #include <inttypes.h>
    #include <avr/io.h>
    #include <util/delay.h>
    #define LCD_RS_PORT PORTB
    #define LCD_RS_PIN 3
    #define LCD_DATA0_PORT   PORTD     /**< port for 4bit data bit 0 */
    #define LCD_DATA1_PORT   PORTD     /**< port for 4bit data bit 1 */
    #define LCD_DATA2_PORT   PORTD     /**< port for 4bit data bit 2 */
    #define LCD_DATA3_PORT   PORTB     /**< port for 4bit data bit 3 */
    #define LCD_DATA0_PIN    5            /**< pin for 4bit data bit 0  */
    #define LCD_DATA1_PIN    6           /**< pin for 4bit data bit 1  */
    #define LCD_DATA2_PIN    7            /**< pin for 4bit data bit 2  */
    #define LCD_DATA3_PIN    0
    #define LCD_RW_PORT      PORTB     /**< port for RW line         */
    #define LCD_RW_PIN       4            /**< pin  for RW line         */
    #define LCD_E_PORT       PORTB     /**< port for Enable line     */
    #define LCD_E_PIN        2            /**< pin  for Enable line     */
    #define LCD_E_PIN        1            /**< pin  for Enable line     */
    void write_data(uint8_t wert)
     if(wert & (1<<0))
       LCD_DATA0_PORT &=  ~(1 << LCD_DATA0_PIN);
     else
       LCD_DATA0_PORT |=  (1 << LCD_DATA0_PIN);
     if(wert & (1<<1))
       LCD_DATA1_PORT &=  ~(1 << LCD_DATA1_PIN);
     else
       LCD_DATA1_PORT |=  (1 << LCD_DATA1_PIN);
     if(wert & (1<<2))
       LCD_DATA2_PORT &=  ~(1 << LCD_DATA2_PIN);
     else
       LCD_DATA2_PORT |=  (1 << LCD_DATA2_PIN);
     if(wert & (1<<3))
       LCD_DATA3_PORT &=  ~(1 << LCD_DATA3_PIN);
     else
       LCD_DATA3_PORT |=  (1 << LCD_DATA3_PIN);
    void init_lcd(void)
     _delay_ms(20);
     LCD_RS_PORT &= ~(1<<LCD_RS_PIN);  /* Steuerregister wird angesprochen */
     _delay_ms(8);
     write_data(0x3);
     _delay_ms(1);
     write_data(0x3);
     LCD_RW_PORT |= (1<<LCD_RW_PIN);                /*Lesezugriff, warten bis RW 0 */
     DDRB = 0xfe;           /*PB0 als Eingang, um Busyflag einzulesen*/
     while(LCD_DATA3_PORT & (1<<LCD_DATA3_PIN));
     LCD_RW_PORT &= ~(1<<LCD_RW_PIN);
     DDRB = 0xff;
     write_data(0x2);
     LCD_RW_PORT |= ~(1<<LCD_RW_PIN);
     DDRB = 0xfe;
     LCD_RW_PORT &= (1<<LCD_RW_PIN);
     DDRB = 0xff;
     write_data(0x2);     /*System-Set oberes Nibble */
     write_data(0x8);     /*System-Set unteres Nibble */
     write_data(0x0);     /*Display on/off, Display on, Unterstrich Cursor on, blinkender Cursor on*/
     write_data(0xF);
     write_data(0x0);   /* Cursor Home */
     write_data(0x2);
     LCD_RS_PORT |= (1<<LCD_RS_PIN);  /*Datenregister auswählen*/
     write_data(0x19);
    void main(void)
     DDRB = 0xFF;
     DDRD = 0xFF;
     init_lcd();
     for(;;);
    Ich habe versucht nach der Anleitung im PDF zu gehen, aber irgendwie habe ich nie Enable verwendet..
    Martin
