Thema: Brauche wass hilfe bei RN_MOTOR I2C
    Ich binn wass es experimenten met demm RN_MOTOR I2C
    Ich habe desen motor
    17HD2402-01N
    hier die daten
    http://www.moons.com.cn/pdf/17HD2402-01N.pdf
    Wie must ich die motoranschlusse an die platine machen
    ich habe jeztz dass folgenden
    10 - blau
    20 - rod
    30 - gelb
    40 - weiss
    Ist dass richtig?
    Ich hab folgendes CCS-C program fur zu testen
    Leider tut dass es nicht immer
    Un in vielen fallen leuchtet dass grune led auf!
    Hieviel volt und ampere muss die spannungquelle haben
    Bitte um hilfe
    John
    #include <18F4620.h>
    #use delay(clock=20000000)
    #fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
    #include <rn-motor.h>
    void main() {
    	i2c_start();
    	i2c_write(RN_MOTOR_ADDR_WRITE);
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_SET_CURRENT);
    	i2c_write(0x00);
    	i2c_write(0xC0);
    	i2c_write(0xFF);
    	i2c_stop();
    	delay_ms(10);
    	i2c_start();
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_STEPPER_MODE);
    	i2c_write(0x00);
    	i2c_write(0xFF);
    	i2c_write(0xFF);
    	i2c_stop();
    	delay_ms(10);
    	i2c_start();
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_SET_STEPS_SECOUND);
    	i2c_write(0x00);
    	i2c_write(0x50);
    	i2c_write(0xFF);
    	i2c_stop();
    	delay_ms(10);
    	i2c_start();
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_SWITCH_MOTOR_ON);
    	i2c_write(0x00);
    	i2c_write(0xFF);
    	i2c_write(0xFF);
    	i2c_stop();
    	delay_ms(10);
    	i2c_start();
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_DIRECTION);
    	i2c_write(0x00);
    	i2c_write(0x00);
    	i2c_write(0xFF);
    	i2c_stop();
    	delay_ms(10);
    	i2c_start();
    	i2c_write(0x0A);
    	i2c_write(RN_MOTOR_ON_FOR_X_STEPS);
    	i2c_write(0x00);
    	i2c_write(0x00);
    	i2c_write(0x10);
    	i2c_stop();
    	delay_ms(10);
    Und hier den include file
    ////                             RN-MOTOR.H                             ////
    ////               Driver for RN-MOTOR controller board                 ////
    #ifndef RN_MOTOR_SDA
    #define RN_MOTOR_SDA PIN_C4
    #define RN_MOTOR_SCL PIN_C3
    #endif
    #use i2c(master,sda=RN_MOTOR_SDA,scl=RN_MOTOR_SCL,FORCE_HW)
    #define RN_MOTOR_ADDR_WRITE         0x56
    #define RN_MOTOR_ADDR_READ          0x57
    // Stepper motor commandset
    #define RN_MOTOR_SET_CURRENT        0x01
    #define RN_MOTOR_REFERENCE_VOLTAGE  0x02
    #define RN_MOTOR_STOP_CURRENT_ON    0x03
    #define RN_MOTOR_DIRECTION          0x04
    #define RN_MOTOR_ON_FOR_X_STEPS     0x05
    #define RN_MOTOR_ON_UNTIL_STOP      0x06
    #define RN_MOTOR_ON_ONE_STEP        0x07
    #define RN_MOTOR_SET_STEPS_SECOUND  0x08
    #define RN_MOTOR_OFF                0x09
    #define RN_MOTOR_SWITCH_MOTOR_ON    0x0A
    #define RN_MOTOR_DISPLAY_CONFIG     0x0B
    #define RN_MOTOR_SLEEP_MODE         0x0C
    #define RN_MOTOR_SELECT_GET_STEPS   0x0D
    #define RN_MOTOR_STEPPER_MODE       0x0E
    #define RN_MOTOR_SET_SLAVE_ID       0x0F
    Während des ersten Tests solltest du delay_ms(10); ruhig mal kräftig erhöhen, kann man später immer noch reduzieren. Es gibt ein oder zwei Befehle die relativ lange brauchen, zum Beispiel der Einschaltbefehl. Wieviel Millisekunden hab ich aber momentan nicht im Kopf.
    Abe rvermutlich liegt dein Problem daran das deine I2C-Befehle das ClockStretching (siehe RN-Wissen unter I2C) nicht berücksichtigen. Manche Compiler kennen das immer noch nicht.
    Die Kabel am Schrittmotor könnten so stimmen. Dreht sich nix, dann höchstens mal 30 - gelb und 40 - weiss vertauschen
    Es sind allerdings sehr stromintensive Motoren, die gehen an die Grenze des machbaren ran.
    Um RN-Motor nicht zu überlasten würde ich die erst mal mit halben Strom ansteuern, vielleicht reicht das ja für deine Anwendung.
    Dein Netzteil sollte bei einem Motor ca. 4A bei zwei ca. 8A verkraften.
    Vielen dank fur die antwort
    Ich habe denn strom bis 600mA heruntergesetzt
    Getzt geht es
