@uC: Ja.
@izaseba: Und hier meine:
Code:/* Copyright (c) 2002, Marek Michalkiewicz All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* $Id: signal.h,v 1.6.2.1 2003/10/09 17:26:14 troth Exp $ */ #ifndef _AVR_SIGNAL_H_ #define _AVR_SIGNAL_H_ /** \name Macros for writing interrupt handler functions */ /*@{*/ /** \def SIGNAL(signame) \ingroup avr_interrupts \code#include <avr/signal.h>\endcode Introduces an interrupt handler function that runs with global interrupts initially disabled. */ #ifdef __cplusplus #define SIGNAL(signame) \ extern "C" void signame(void); \ void signame (void) __attribute__ ((signal)); \ void signame (void) #else #define SIGNAL(signame) \ void signame (void) __attribute__ ((signal)); \ void signame (void) #endif /** \def INTERRUPT(signame) \ingroup avr_interrupts \code#include <avr/signal.h>\endcode Introduces an interrupt handler function that runs with global interrupts initially enabled. This allows interrupt handlers to be interrupted. */ #ifdef __cplusplus #define INTERRUPT(signame) \ extern "C" void signame(void); \ void signame (void) __attribute__ ((interrupt)); \ void signame (void) #else #define INTERRUPT(signame) \ void signame (void) __attribute__ ((interrupt)); \ void signame (void) #endif /** \def EMPTY_INTERRUPT(signame) \ingroup avr_interrupts \code#include <avr/signal.h>\endcode Defines an empty interrupt handler function. This will not generate any prolog or epilog code and will only return from the ISR. Do not define a function body as this will define it for you. Example: \code EMPTY_INTERRUPT(SIG_ADC);\endcode */ #ifdef __cplusplus #define EMPTY_INTERRUPT(signame) \ extern "C" void signame(void); \ void signame (void) __attribute__ ((naked)); \ void signame (void) { __asm__ __volatile__ ("reti" ::); } #else #define EMPTY_INTERRUPT(signame) \ void signame (void) __attribute__ ((naked)); \ void signame (void) { __asm__ __volatile__ ("reti" ::); } #endif /*@}*/ #endif /* _AVR_SIGNAL_H_ */
Zitieren
