Mahlzeit,
ich habe schon viele Problemfälle mit dem T6963C hier gelesen, doch leider hat mir keine Lösung geholfen.
Ich möchte auf dem LCD einen Font ins Ram laden, der 8x12 Pixel hat. leider macht dieses das LCD nicht mit. Nach dem ich die Fontdaten ins Ram geladen habe, blinkt es wild und Resetet sich selbst und dann bleibt auch meine MCU stehen.
Bascom meldet:
Forward jump out of range[_GWRITE_DATA[2607]]
Matthias
$regfile = "m128def.dat"
$crystal = 14745600
Dim Gl_byte As Byte
Dim V As Byte
Dim K As Byte
Dim P As Byte
Dim W As Word
Dim Q As String * 1
Dim Btxt As String * 16 'string to be printed
Declare Sub Text(sf As String ) 'sub that prints the big text
Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 2 , Cd = 3 , Wr = 0 , Rd = 1 , Reset = 4 , Fs = 5 , Mode = 8
Cls
Cursor Off
Wait 1
'set offset
ldi r24,&h03 'load r24 with offset location low byte
rcall _GWrite_Data
ldi r24,&h00 'load r24 with offset location high byte
Rcall _GWrite_Data
ldi r24,&h22 'set offset command
rcall _GWrite_Cmd 'write command to LCD
'set address pointer
ldi r20,&h00 'address that pointer will point to
ldi r21,&h1c 'set address pointer command
rcall _set_address 'set address routine
'store characters
Restore Font_big 'select font_big table
For W = 1 To 288 'read each fontc table byte into
Read Gl_byte 'read a byte from the table
Loadadr Gl_byte , X 'load register x with gl_byte address
ld r24, x 'load r24 with gl_byte
rcall _GWrite_Data
ldi r24, &hc0 'command to write and increment pointer
rcall _GWrite_Cmd
Next W
'display Character
Locate 2 , 1 'set cursor location
Btxt = "ABCDEFGHIJKLMNOP" 'set Btext with text to be printed
Call Text(btxt) 'call text sub
Locate 3 , 1
Btxt = "QRSTUVWXYZ"
Call Text(btxt)
Locate 4 , 1
Btxt = "0123456789"
Call Text(btxt)
End
'sub used to display characters
 Sub Text(sf As String ) '!!!!!sf text must be in caps to work!!!!
V = Len(sf) 'get length of string
For K = 1 To V 'repeat until end of string
Q = Mid(sf , K , 1) 'read each character
P = Asc(q) 'convert to ascII
If P < 65 Then 'adjust ascII code
 P = P + 106
 Else
 P = P + 63
End If
Loadadr P , X 'load x with address of p
ld r24,x 'load r24 with p
rcall _GWrite_Data 'write and increment
ldi r24,&hc0
rcall _GWrite_Cmd
Next K
End Sub
Font_big:
Data &H0 , &H0 , &H2 , &H6 , &HC , &H18 , &H30 , &H60 , &HC0 , &H80 , &H0 , &H0       ''/'47
Data &H0 , &H7C , &HC6 , &HCE , &HDE , &HF6 , &HE6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''0'48
Data &H0 , &H18 , &H78 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H7E , &H0 , &H0       ''1'49
Data &H0 , &H7C , &HC6 , &HC6 , &HC , &H18 , &H30 , &H60 , &HC6 , &HFE , &H0 , &H0       ''2'50
Data &H0 , &H7C , &HC6 , &H6 , &H6 , &H3C , &H6 , &H6 , &HC6 , &H7C , &H0 , &H0       ''3'51
Data &H0 , &HC , &H1C , &H3C , &H6C , &HCC , &HFE , &HC , &HC , &HC , &H0 , &H0       ''4'52
Data &H0 , &HFE , &HC0 , &HC0 , &HC0 , &HFC , &H6 , &H6 , &HC6 , &H7C , &H0 , &H0       ''5'53
Data &H0 , &H7C , &HC6 , &HC0 , &HC0 , &HFC , &HC6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''6'54
Data &H0 , &HFE , &HC6 , &HC , &H18 , &H30 , &H30 , &H30 , &H30 , &H30 , &H0 , &H0       ''7'55
Data &H0 , &H7C , &HC6 , &HC6 , &HC6 , &H7C , &HC6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''8'56
Data &H0 , &H7C , &HC6 , &HC6 , &HC6 , &H7E , &H6 , &H6 , &HC6 , &H7C , &H0 , &H0       ''9'57
Data &H0 , &H0 , &H0 , &HC , &HC , &H0 , &H0 , &HC , &HC , &H0 , &H0 , &H0       '':'58
Data &H0 , &H0 , &H0 , &HC , &HC , &H0 , &H0 , &HC , &HC , &HC , &H18 , &H0       ''
Data &H0 , &HC , &H18 , &H30 , &H60 , &HC0 , &H60 , &H30 , &H18 , &HC , &H0 , &H0       ''<'60
Data &H0 , &H0 , &H0 , &H0 , &HFE , &H0 , &HFE , &H0 , &H0 , &H0 , &H0 , &H0       ''='61
Data &H0 , &H60 , &H30 , &H18 , &HC , &H6 , &HC , &H18 , &H30 , &H60 , &H0 , &H0       ''>'62
Data &H0 , &H7C , &HC6 , &HC6 , &HC , &H18 , &H18 , &H0 , &H18 , &H18 , &H0 , &H0       ''?'63
Data &H0 , &H7C , &HC6 , &HC6 , &HDE , &HDE , &HDE , &HDC , &HC0 , &H7E , &H0 , &H0       ''@'64
Data &H0 , &H38 , &H6C , &HC6 , &HC6 , &HC6 , &HFE , &HC6 , &HC6 , &HC6 , &H0 , &H0       ''A'65
Data &H0 , &HFC , &H66 , &H66 , &H66 , &H7C , &H66 , &H66 , &H66 , &HFC , &H0 , &H0       ''B'66
Data &H0 , &H3C , &H66 , &HC0 , &HC0 , &HC0 , &HC0 , &HC0 , &H66 , &H3C , &H0 , &H0       ''C'67
Data &H0 , &HF8 , &H6C , &H66 , &H66 , &H66 , &H66 , &H66 , &H6C , &HF8 , &H0 , &H0       ''D'68
Data &H0 , &HFE , &H66 , &H60 , &H60 , &H7C , &H60 , &H60 , &H66 , &HFE , &H0 , &H0       ''E'69
Data &H0 , &HFE , &H66 , &H60 , &H60 , &H7C , &H60 , &H60 , &H60 , &HF0 , &H0 , &H0       ''F'70
Data &H0 , &H7C , &HC6 , &HC6 , &HC0 , &HC0 , &HCE , &HC6 , &HC6 , &H7C , &H0 , &H0       ''G'71
Data &H0 , &HC6 , &HC6 , &HC6 , &HC6 , &HFE , &HC6 , &HC6 , &HC6 , &HC6 , &H0 , &H0       ''H'72
Data &H0 , &H3C , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H3C , &H0 , &H0       ''I'73
Data &H0 , &H3C , &H18 , &H18 , &H18 , &H18 , &H18 , &HD8 , &HD8 , &H70 , &H0 , &H0       ''J'74
Data &H0 , &HC6 , &HCC , &HD8 , &HF0 , &HF0 , &HD8 , &HCC , &HC6 , &HC6 , &H0 , &H0       ''K'75
Data &H0 , &HF0 , &H60 , &H60 , &H60 , &H60 , &H60 , &H62 , &H66 , &HFE , &H0 , &H0       ''L'76
Data &H0 , &HC6 , &HC6 , &HEE , &HFE , &HD6 , &HD6 , &HD6 , &HC6 , &HC6 , &H0 , &H0       ''M'77
Data &H0 , &HC6 , &HC6 , &HE6 , &HE6 , &HF6 , &HDE , &HCE , &HCE , &HC6 , &H0 , &H0       ''N'78
Data &H0 , &H7C , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''O'79
Data &H0 , &HFC , &H66 , &H66 , &H66 , &H7C , &H60 , &H60 , &H60 , &HF0 , &H0 , &H0       ''P'80
Data &H0 , &H7C , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HD6 , &H7C , &H6 , &H0       ''Q'81
Data &H0 , &HFC , &H66 , &H66 , &H66 , &H7C , &H78 , &H6C , &H66 , &HE6 , &H0 , &H0       ''R'82
Data &H0 , &H7C , &HC6 , &HC0 , &H60 , &H38 , &HC , &H6 , &HC6 , &H7C , &H0 , &H0       ''S'83
Data &H0 , &H7E , &H5A , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H3C , &H0 , &H0       ''T'84
Data &H0 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''U'85
Data &H0 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &HC6 , &H6C , &H38 , &H10 , &H0 , &H0       ''V'86
Data &H0 , &HC6 , &HC6 , &HD6 , &HD6 , &HD6 , &HFE , &HEE , &HC6 , &HC6 , &H0 , &H0       ''W'87
Data &H0 , &HC6 , &HC6 , &H6C , &H38 , &H38 , &H38 , &H6C , &HC6 , &HC6 , &H0 , &H0       ''X'88
Data &H0 , &H66 , &H66 , &H66 , &H66 , &H3C , &H18 , &H18 , &H18 , &H3C , &H0 , &H0       ''Y'89
Data &H0 , &HFE , &HC6 , &H8C , &H18 , &H30 , &H60 , &HC2 , &HC6 , &HFE , &H0 , &H0       ''Z'90
Data &H0 , &H0 , &H0 , &H0 , &H78 , &HC , &H7C , &HCC , &HDC , &H76 , &H0 , &H0       ''a'97
Data &H0 , &HE0 , &H60 , &H60 , &H7C , &H66 , &H66 , &H66 , &H66 , &HFC , &H0 , &H0       ''b'98
Data &H0 , &H0 , &H0 , &H0 , &H7C , &HC6 , &HC0 , &HC0 , &HC6 , &H7C , &H0 , &H0       ''c'99
Data &H0 , &H1C , &HC , &HC , &H7C , &HCC , &HCC , &HCC , &HCC , &H7E , &H0 , &H0       ''d'100
Data &H0 , &H0 , &H0 , &H0 , &H7C , &HC6 , &HFE , &HC0 , &HC6 , &H7C , &H0 , &H0       ''e'101
Data &H0 , &H1C , &H36 , &H30 , &H30 , &HFC , &H30 , &H30 , &H30 , &H78 , &H0 , &H0       ''f'102
Data &H0 , &H0 , &H0 , &H0 , &H76 , &HCE , &HC6 , &HC6 , &H7E , &H6 , &HC6 , &H7C       ''g'103
Data &H0 , &HE0 , &H60 , &H60 , &H6C , &H76 , &H66 , &H66 , &H66 , &HE6 , &H0 , &H0       ''h'104
Data &H0 , &H18 , &H18 , &H0 , &H38 , &H18 , &H18 , &H18 , &H18 , &H3C , &H0 , &H0       ''i'105
Data &H0 , &HC , &HC , &H0 , &H1C , &HC , &HC , &HC , &HC , &HCC , &HCC , &H78       ''j'106
Data &H0 , &HE0 , &H60 , &H60 , &H66 , &H6C , &H78 , &H6C , &H66 , &HE6 , &H0 , &H0       ''k'107
Data &H0 , &H38 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H3C , &H0 , &H0       ''l'108
Data &H0 , &H0 , &H0 , &H0 , &H6C , &HFE , &HD6 , &HD6 , &HC6 , &HC6 , &H0 , &H0       ''m'109
Data &H0 , &H0 , &H0 , &H0 , &HDC , &H66 , &H66 , &H66 , &H66 , &H66 , &H0 , &H0       ''n'110
Data &H0 , &H0 , &H0 , &H0 , &H7C , &HC6 , &HC6 , &HC6 , &HC6 , &H7C , &H0 , &H0       ''o'111
Data &H0 , &H0 , &H0 , &H0 , &HDC , &H66 , &H66 , &H66 , &H7C , &H60 , &H60 , &HF0       ''p'112
Data &H0 , &H0 , &H0 , &H0 , &H76 , &HCC , &HCC , &HCC , &H7C , &HC , &HC , &H1E       ''q'113
Data &H0 , &H0 , &H0 , &H0 , &HDC , &H66 , &H60 , &H60 , &H60 , &HF0 , &H0 , &H0       ''r'114
Data &H0 , &H0 , &H0 , &H0 , &H7C , &HC6 , &H70 , &H1C , &HC6 , &H7C , &H0 , &H0       ''s'115
Data &H0 , &H30 , &H30 , &H30 , &HFC , &H30 , &H30 , &H30 , &H36 , &H1C , &H0 , &H0       ''t'116
Data &H0 , &H0 , &H0 , &H0 , &HCC , &HCC , &HCC , &HCC , &HCC , &H76 , &H0 , &H0       ''u'117
Data &H0 , &H0 , &H0 , &H0 , &HC6 , &HC6 , &HC6 , &H6C , &H38 , &H10 , &H0 , &H0       ''v'118
Data &H0 , &H0 , &H0 , &H0 , &HC6 , &HC6 , &HD6 , &HD6 , &HFE , &H6C , &H0 , &H0       ''w'119
Data &H0 , &H0 , &H0 , &H0 , &HC6 , &H6C , &H38 , &H38 , &H6C , &HC6 , &H0 , &H0       ''x'120
Data &H0 , &H0 , &H0 , &H0 , &HC6 , &HC6 , &HC6 , &HCE , &H76 , &H6 , &HC6 , &H7C       ''y'121
Data &H0 , &H0 , &H0 , &H0 , &HFE , &H8C , &H18 , &H30 , &H62 , &HFE , &H0 , &H0       ''z'122
Data &H0 , &H0 , &H0 , &H0 , &H0 , &H7E , &H60 , &H60 , &H60 , &H0 , &H0 , &H0       ''©'169
Data &H0 , &H0 , &H0 , &H36 , &H6C , &HD8 , &H6C , &H36 , &H0 , &H0 , &H0 , &H0       ''®'174
Data &HDD , &H77 , &HDD , &H77 , &HDD , &H77 , &HDD , &H77 , &HDD , &H77 , &HDD , &H77       ''²'178
Data &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18 , &H18       ''³'179
Data &H0 , &H0 , &H0 , &H0 , &H0 , &H0 , &HFF , &H0 , &H0 , &H0 , &H0 , &H0       ''Ä'196
Data &H0 , &H0 , &H0 , &H0 , &H0 , &H0 , &H3F , &H36 , &H36 , &H36 , &H36 , &H36       ''Ö'214
Data &H0 , &H0 , &H0 , &H0 , &H0 , &H0 , &HFF , &HFF , &HFF , &HFF , &HFF , &HFF       ''Ü'220
Data &HFF , &HFF , &HFF , &HFF , &HFF , &HFF , &H0 , &H0 , &H0 , &H0 , &H0 , &H0       ''ß'223
Data &H0 , &HFE , &HC6 , &H62 , &H30 , &H18 , &H30 , &H62 , &HC6 , &HFE , &H0 , &H0       ''ä'228
Data &H0 , &H3E , &H60 , &H30 , &H3C , &H66 , &HC6 , &HC6 , &HCC , &H78 , &H0 , &H0       ''ë'235
Data &H0 , &H0 , &H18 , &H18 , &H0 , &H7E , &H0 , &H18 , &H18 , &H0 , &H0 , &H0       ''ö'246
Data &HD8 , &H6C , &H6C , &H6C , &H6C , &H0 , &H0 , &H0 , &H0 , &H0 , &H0 , &H0       ''ü'252
