Kann mir Jemand weiter helfen wo es bei mir Hackt? Hab 2 Mega16 so programmiert. Aber der Slave macht nix. Woran liegt es?
Bitte Hellft mir!!!!!!Code:Master: $regfile = "m16def.dat" $crystal = 1000000 $baud = 9600 Dim A As Byte Dim B As Byte Dim C As Byte Dim D As Byte Open "comd.2:2400,8,n,1,inverted" For Output As #1 Open "comd.3:2400,8,n,1,inverted" For Input As #2 Config Porta = Input A = 200 B = 100 C = 1 D = 201 Do If Pina.0 = 0 Then Printbin #1 , A Printbin #1 , B Printbin #1 , C Printbin #1 , D End If Loop Close #1 Close #2 End Slave: $regfile = "m16def.dat" $crystal = 1000000 $baud = 9600 Led1 Alias Porta.0 Config Porta = Output Dim A As Byte Dim B As Byte Dim C As Byte Dim E As Byte Open "comd.3:2400,8,n,1,inverted" For Output As #1 Open "comd.2:2400,8,n,1,inverted" For Input As #2 Do Ende: A = Waitkey(#2) If A = 200 Then Porta.1 = 1 B = Waitkey(#2) End If If B = 100 Then Set Led1 Waitms 500 Reset Led1 Goto Ende End If Loop Close #1 Close #2 End
Zitieren
