ich hab jetzt eure makefile verwendet:
Fehler: (Von make.exe angezeigt)Code:MCU = atmega16 #Tagret einstellen TARGET = taster_und_led #Sourcefiles SRC = $(TARGET).c SRC += FORMAT = ihex #Assemblerfiles ASRC= OPT = s #Compilerflags CFLAGS = -g -O$(OPT) \ -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \ -Wall -Wstrict-prototypes \ -Wa,-ahlms=$(<:.c=.lst) #Assemblerflags ASFLAGS = -Wa,-ahlms=$(<:.S=.lst),-gstabs #Linkerflags LDFLAGS = -Wl,-Map=$(TARGET).map,--cref # Additional libraries # # Minimalistic printf version #LDFLAGS += -Wl,-u,vfprintf -lprintf_min # # Floating point printf version (requires -lm below) #LDFLAGS += -Wl,-u,vfprintf -lprintf_flt # # -lm = math library LDFLAGS += -lm # Define programs and commands. SHELL = sh CC = avr-gcc OBJCOPY = avr-objcopy OBJDUMP = avr-objdump SIZE = avr-size REMOVE = rm -f COPY = cp HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex ELFSIZE = $(SIZE) -A $(TARGET).elf FINISH = echo Errors: none BEGIN = echo -------- begin -------- END = echo -------- end -------- # Define all object files. OBJ = $(SRC:.c=.o) $(ASRC:.S=.o) # Define all listing files. LST = $(ASRC:.S=.lst) $(SRC:.c=.lst) # Combine all necessary flags and optional flags. # Add target processor to flags. ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS) # Default target. all: begin gccversion sizebefore $(TARGET).elf $(TARGET).hex $(TARGET).eep \ $(TARGET).lss sizeafter finished end # Eye candy. # AVR Studio 3.x does not check make's exit code but relies on # the following magic strings to be generated by the compile job. begin: @$(BEGIN) finished: @$(FINISH) end: @$(END) # Display size of file. sizebefore: @if [ -f $(TARGET).elf ]; then echo Size before:; $(ELFSIZE);fi sizeafter: @if [ -f $(TARGET).elf ]; then echo Size after:; $(ELFSIZE);fi # Display compiler version information. gccversion : $(CC) --version # Convert ELF to COFF for use in debugging / simulating in # AVR Studio or VMLAB. COFFCONVERT=$(OBJCOPY) --debugging \ --change-section-address .data-0x800000 \ --change-section-address .bss-0x800000 \ --change-section-address .noinit-0x800000 \ --change-section-address .eeprom-0x810000 coff: $(TARGET).elf $(COFFCONVERT) -O coff-avr $< $(TARGET).cof extcoff: $(TARGET).elf $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof # Create final output files (.hex, .eep) from ELF output file. %.hex: %.elf $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@ %.eep: %.elf -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \ --change-section-lma .eeprom=0 -O $(FORMAT) $< $@ # Create extended listing file from ELF output file. %.lss: %.elf $(OBJDUMP) -h -S $< > $@ # Link: create ELF output file from object files. .SECONDARY : $(TARGET).elf .PRECIOUS : $(OBJ) %.elf: $(OBJ) $(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS) # Compile: create object files from C source files. %.o : %.c $(CC) -c $(ALL_CFLAGS) $< -o $@ # Compile: create assembler files from C source files. %.s : %.c $(CC) -S $(ALL_CFLAGS) $< -o $@ # Assemble: create object files from assembler source files. %.o : %.S $(CC) -c $(ALL_ASFLAGS) $< -o $@ # Target: clean project. clean: begin clean_list finished end clean_list : $(REMOVE) $(TARGET).hex $(REMOVE) $(TARGET).eep $(REMOVE) $(TARGET).obj $(REMOVE) $(TARGET).cof $(REMOVE) $(TARGET).elf $(REMOVE) $(TARGET).map $(REMOVE) $(TARGET).obj $(REMOVE) $(TARGET).a90 $(REMOVE) $(TARGET).sym $(REMOVE) $(TARGET).lnk $(REMOVE) $(TARGET).lss $(REMOVE) $(OBJ) $(REMOVE) $(LST) $(REMOVE) $(SRC:.c=.s) $(REMOVE) $(SRC:.c=.d) # Automatically generate C source code dependencies. # (Code originally taken from the GNU make user manual and modified # (See README.txt Credits).) # # Note that this will work with sh (bash) and sed that is shipped with WinAVR # (see the SHELL variable defined above). # This may not work with other shells or other seds. # %.d: %.c set -e; $(CC) -MM $(ALL_CFLAGS) $< \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > $@; \ [ -s $@ ] || rm -f $@ # Remove the '-' if you want to see the dependency files generated. -include $(SRC:.c=.d) # Listing of phony targets. .PHONY : all begin finish end sizebefore sizeafter gccversion coff extcoff \ clean clean_list program #
Könntet ihr mir bitte eine komplette makefile mit Ponyprog senden da ich ja noch nicht so viel ahnung habe.Code:Makefile:86: *** missing separator. Stop.
Daten:
Mega16
14,7456MHz
led_taster_2.c
Danke
Thomas
PS: mit avr-gcc gehts. Braucht das keine makefile, oder. Dafür muss halt als in den parametern stehen und Ponyprog brauch ich auch noch extra.
Zitieren
