Ergebnis 21 bis 30 von 41
Thema: M8 TWI-slave in M32 umschreiben.
    Aarau
    hmmm komisch........
    eigentlich solte es jetzt funktionieren... er sollte direkt nacheinander in beide subs springen...
    poste doch bitte mal deine jetzigen beiden programme...
    bei mir funktiniert das so...
    Bayern
    Komisch ist das schon weil egal was ich bei scl und sda eingebe er meldet immer master needs byte
    Master:
    $regfile = "M32def.dat"                           ' the used chip
    $crystal = 16000000                               ' frequency used
    $baud = 9600                                      ' baud rate
    $lib "i2c_twi.lbx"                                          ' we do not use software emulated I2C but the TWI
    Config Scl = Portc.0                              ' we need to provide the SCL pin name
    Config Sda = Portc.1                              ' we need to provide the SDA pin name
    I2cinit                                                     ' we need to set the pins in the proper state
    Config Twi = 100000                                         ' wanted clock frequency
    'will set TWBR and TWSR
    'Twbr = 12                                                   'bit rate register
    'Twsr = 0                                                    'pre scaler bits
    Dim B As Byte , X As Byte
    Print "TWI master"
    B = 125
    Do
                                                        ' increase value
      I2csend &H70 , B                                          ' send the value
                                          ' show error
      Waitms 500                                                'wait a bit
    Loop
    End
    Slave:
    $regfile = "M32def.dat"                           ' the chip we use
    $crystal = 16000000                               ' crystal oscillator value
    Print "MCS Electronics TWI-slave demo"
        Config Twislave = &H70 , Btr = 1 , Bitrate = 100000
        ' the code below #else is executed by the compiler when you use version 11175 or higher
    'as you might need other interrupts as well, you need to enable them manual
    Enable Interrupts
    'this is just an empty loop but you could perform other tasks there
    Do
     nop
    Loop
    End
    'A master can send or receive bytes.
    'A master protocol can also send some bytes, then receive some bytes
    'The master and slave must match.
    'the following labels are called from the library
    Twi_stop_rstart_received:
      Print "Master sent stop or repeated start"
    Return
    Twi_addressed_goread:
      Print "We were addressed and master will send data"
    Return
    Twi_addressed_gowrite:
      Print "We were addressed and master will read data"
    Return
    'this label is called when the master sends data and the slave has received the byte
    'the variable TWI holds the received value
    Twi_gotdata:
       Print "received : " ; Twi
    Return
    'this label is called when the master receives data and needs a byte
    'the variable twi_btr is a byte variable that holds the index of the needed byte
    'so when sending multiple bytes from an array, twi_btr can be used for the index
    Twi_master_needs_byte:
      Print "Master needs byte : " ; Twi_btr
      Twi = 65                                                  ' twi must be filled with a value
    Return
    'when the mast has all bytes received this label will be called
    Twi_master_need_nomore_byte:
      Print "Master does not need anymore bytes"
    Return
    Aarau
    ich habe gerade in meinen programmen geschaut und habe festgestellt das ich da die falschen pins für sda und scl definiert habe... anscheinend spielt es keine rolle was man da eingiebt...
    aber im moment sehe ich keine fehler mehr in deinen prog... sollte eigentlich funktionieren so... es hat ja bei mir auch funktioniert mit nem mega32 als master und nem mega8 als slave und auch umgekehrt...
    vielleicht sieht hier noch jemand anderes einen fehler...
    Aarau
    ist bei dir die verdrahtung in ordnung? hast 10k pullup's an den leitungen?
    Bayern
    Ich hab den fehler.
    ich habe die baudrate auf 19200 gestellt sont war sie immer auf 9600.
    jetzt funktionierts.
    warum weis ich aber auch nicht.
    Danke für deine Hilfe und dass du so viel Gedult mit mir gehapt hast.
    nur mit dem empfangen klapts noch nicht so ganz.
    Aarau
    was?? aber das hat ja gar nichts mit dem I2C zu tun.... und die ausgabe auf den pc war ja ok?? komisch....
    dank dir steige ich bald einen rang auf
    Bayern
    Da sendet mir der master
    TWI master
    X113
    X196
    X136
    X113
    X113
    X196
    X136
    X113
    X113
    X196
    X136
    X113
    X113
    X196
    und der Slave
    Master needs byte : 1
    und das steht im Masterprogramm:
    Do
                                                        ' increase value
       I2creceive &H71 , X                            ' send the value
       Print "X" ; X
                                          ' show error
    Loop
    End
    fehlt da nich noch eine sub mit sent oder so. weil received gibts ja auch
    Aarau
    das sieht doch schonmal nicht schlecht aus... was übergibst du den der twi variabel im slave?
    das senden vom master aus klapt? hast du den beitrag oben von mir gesehen wegen der pullup's?
  9. #29
    Bayern
    Ja die Pullups hab ich. jeweils einen 10k an scl und sda.
    die verkabelung muss ja passen da das senden vom master ja super funktioniert.
    im slave steht
    Twi = 65
    Return
  10. #30
    Aarau
    komisch sind die zahlen die du im master bekommst eigentlich sollte er ja 65 zurückbekommen...
    ach mal weiter oben im code:
    dim b as byte
    b=65
    und dann in der sub twi=b
    dann soltest du beim master x65 erhalten... wenn nicht kann ich im moment auch nicht sagen wiso...
