juhu, es geht...danke PicNick.....
war ein Fehler meiner gedanken. Natürlich muß ich die Overlayadadresse um 2 Verschieben....jetzt gehts!!
Code:$lib "i2c.lib" Config Scl = Portc.0 'PIN für I2C Bus Config Sda = Portc.1 I2cinit Config I2cdelay = 3 Dim Eesingle As Single Dim Eeword(2) As Word At Eesingle Overlay Dim Eebyte(6) As Byte At Eesingle + 2 Overlay '<------um 2 verschoben!!! Dim Eebanz As Byte Dim Ee_adresse As Word Const 24c64w = &B10100000 Const 24c64r = &B10100001 Const Eetest = 0 'Definition der Funktionen ++++++++++++++++++++++++++++++++++++++++++++++++++++ Declare Function Loadbyte(byval Ee_adresse As Word) As Byte Declare Function Loadword(byval Ee_adresse As Word) As Word Declare Function Loadsingle(byval Ee_adresse As Word) As Single Declare Sub Savebyte(byval Ee_daten As Byte , Byval Ee_adresse As Word) Declare Sub Saveword(byval Ee_daten As Word , Byval Ee_adresse As Word) Declare Sub Savesingle(byval Ee_daten As Single , Byval Ee_adresse As Word ) Goto 001 Sub Savebyte(byval Ee_daten As Byte , Byval Ee_adresse As Word) Eebyte(3) = Ee_daten Ee_adresse = Ee_adresse Eebanz = 1 + 2 : Gosub Write_ee End Sub Sub Saveword(byval Ee_daten As Word , Byval Ee_adresse As Word) Eeword(2) = Ee_daten Ee_adresse = Ee_adresse Eebanz = 2 + 2 : Gosub Write_ee End Sub Sub Savesingle(byval Ee_daten As Single , Byval Ee_adresse As Word ) Eesingle = Ee_daten Ee_adresse = Ee_adresse Eebanz = 4 + 2 : Gosub Write_ee End Sub Function Loadbyte(byval Ee_adresse As Word) As Byte Ee_adresse = Ee_adresse Eebanz = 1 : Gosub Read_ee Loadbyte = Eebyte(3) End Function Function Loadword(byval Ee_adresse As Word) As Word Ee_adresse = Ee_adresse Eebanz = 2 : Gosub Read_ee Loadword = Eeword(2) End Function Function Loadsingle(byval Ee_adresse As Word) As Single Ee_adresse = Ee_adresse Eebanz = 4 : Gosub Read_ee Loadsingle = Eesingle End Function 'Routine zum schreiben von Daten in das EEPROM ++++++++++++++++++++++++++++++++ Write_ee: Eebyte(1) = Low(ee_adresse) Eebyte(2) = High(ee_adresse) I2csend 24c64w , Eebyte(1) , Eebanz Waitms 30 Return 'Routine zum lesen von Daten aus dem EEPROM ++++++++++++++++++++++++++++++++++++ Read_ee: Eebyte(1) = Low(ee_adresse) Eebyte(2) = High(ee_adresse) I2csend 24c64w , Eebyte(1) , 2 Waitms 5 I2creceive 24c64r , Eebyte(3) , 0 , Eebanz Waitms 25 Return 001: Dim Ins As Single Dim Inw As Word Dim Inb As Byte Do Input "Single: " , Ins Call Savesingle(ins , 100) Print "gespeicherter Wert: ";ins Ins = Loadsingle(100) Print "geladener Wert: " ; Ins Input "Word: " , Inw Call Saveword(inw , 100) Print "gespeicherter Wert: " ; Inw Inw = Loadword(100) Print "geladener Wert: " ; Inw Input "Byte: " , Inb Call Savebyte(inb , 100) Print "gespeicherter Wert: " ; Inb Inb = Loadbyte(100) Print "geladener Wert: " ; Inb Loop
Zitieren
