Doch da war ein Beispielprogramm dabei, doch da zeigt Bascom mir auch nur fehler an.Code:'------------------------------------------------------------------------------- ' (c) 2004 MCS Electronics ' This demo shows an example of the TWI in SLAVE mode ' Not all AVR chips have TWI (hardware I2C) '------------------------------------------------------------------------------- $regfile = "M32def.dat" $crystal = 16000000 $baud = 9600 Print "MCS Electronics TWI-slave demo" #if _build >= 11175 Config Twislave = &H70 , Btr = 1 , Bitrate = 100000 ' the code below #else is executed by the compiler when you use version 11175 or higher #else 'as this is available in 1.11.7.5 some manual work mus tbe done $lib "i2c_twi-slave.lbx" ' include $external _twi_slave 'include code from the lib Const _twisdaport = Portd Const _twisclport = Portd Const _twisdaddr = Ddrd Const _twisclddr = Ddrd Const _twisda = 1 Const _twiscl = 0 Const Twi_cbtr = 1 'how many bytes we will receive Dim Twi As Byte , Twi_btr As Byte rcall _twi_init Twbr = 12 'bit rate register Twsr = 0 Twar = &B01110000 ' own slave address Twcr = &B01000101 'general call not enabled On Twi _twi_slave_isr Nosave Enable Twi #endif 'as you might need other interrupts as well, you need to enable them manual Enable Interrupts 'this is just an empty loop but you could perform other tasks there Do nop Loop End 'A master can send or receive bytes. 'A master protocol can also send some bytes, then receive some bytes 'The master and slave must match. 'the following labels are called from the library Twi_stop_rstart_received: Print "Master sent stop or repeated start" Return Twi_addressed_goread: Print "We were addressed and master will send data" Return 'this label is called when the master sends data and the slave has received the byte 'the variable TWI holds the received value Twi_gotdata: Print "received : " ; Twi Return 'this label is called when the master receives data and needs a byte 'the variable twi_btr is a byte variable that holds the index of the needed byte 'so when sending multiple bytes from an array, twi_btr can be used for the index Twi_master_needs_byte: Print "Master needs byte : " ; Twi_btr Twi = 65 ' twi must be filled with a value Return 'when the mast has all bytes received this label will be called Twi_master_need_nomore_byte: Print "Master does not need anymore bytes" Return
Zitieren
