Hier ein Beispielscript, mit dem man den ASURO aus SCILAB heraus fernsteuern kann:
Damit das funktioniert, muss man vorher die beiden scripfiles asuro_links und asuro_rechts wie hier beschriebenCode:function turn(degrees) // ASURO turn // v0.1 5.1.2006 stochri digit_per_turn=68; digit=abs(degrees/360*digit_per_turn); realtimeinit(0.1); realtime(0); for k=1:digit, realtime(k); if degrees>0, unix ./asuro_rechts; else unix ./asuro_links; end end endfunction // ------------------------------------------------------------------------- // This file ist made for scilab the free mathematical toolbox // // Copyright (C) 2006 stochri // // This program is free software; you can redistribute it and/or modify // it under the terms of the GNU General Public License as published by // the Free Software Foundation; either version 2 of the License, or // (at your option) any later version. // // This program is distributed in the hope that it will be useful, // but WITHOUT ANY WARRANTY; without even the implied warranty of // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the // GNU General Public License for more details. // // You should have received a copy of the GNU General Public License // along with this program; if not, write to the Free Software // Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA // ------------------------------------------------------------------------- //
https://www.roboternetz.de/phpBB2/viewtopic.php?t=15726
erzeugen.
Gruss,
stochri
