Und in C sieht es so aus:
Code://Dup the function of sched1.asm //used as an example in the program organization doc. #include <90s8515.h> //timeout values for each task #define t1 250 #define t2 125 #define t3 60 //the three task subroutines void task1(void); //blink at 2 or 8 Hz void task2(void); //blink at 1 Hz void task3(void); //detect button and modify task 1 rate void initialize(void); //all the usual mcu stuff unsigned char reload; //timer 0 reload to set 1 mSec unsigned char time1, time2, time3; //timeout counters unsigned char tsk2c; //task 2 counter to get to 1/2 second unsigned char tsk3m; //task 3 message to task 1 unsigned char led; //light states //********************************************************** //timer 0 overflow ISR interrupt [TIM0_OVF] void timer0_overflow(void) { //reload to force 1 mSec overflow TCNT0=reload; //Decrement the three times if they are not already zero if (time1>0) --time1; if (time2>0) --time2; if (time3>0) --time3; } //********************************************************** //Entry point and task scheduler loop void main(void) { initialize(); //main task scheduler loop while(1) { if (time1==0) task1(); if (time2==0) task2(); if (time3==0) task3(); } } //********************************************************** //Task subroutines //Task 1 void task1(void) { time1=t1; //reset the task timer if (tsk3m != 0) time1 >>= 2; //check for task 3 message //toggle the zeros bit if ((led & 0x01) == 0) led = led | 0x01; else led = led & 0xfe; PORTB = led; } //******************************* //Task 2 void task2(void) { time2=t2; //reset the task timer if (--tsk2c == 0) //have we waited 1/2 second? { tsk2c = 4; //reload the 1/2 sec counter //toggle the ones bit if ((led & 0x02) == 0) led = led | 0x02; else led = led & 0xfd; PORTB = led; } } //******************************* //Task 3 void task3(void) { time3=t3; //reset the task timer tsk3m = ~PIND & 0x01; //generate the message for task 1 } //********************************************************** //Set it all up void initialize(void) { //set up the ports DDRD=0x00; // PORT D is an input DDRB=0xff; // PORT B is an ouput PORTB=0; //set up timer 0 reload=256-62; //value for 1 Msec TCNT0=reload; TIMSK=2; //turn on timer 0 overflow ISR TCCR0=3; //prescalar to 64 //init the LED status (all off) led=0xff; //init the task timers time1=t1; time2=t2; time3=t3; //init the task 2 state variable //for four ticks tsk2c=4; //init the task 3 message //for no message tsk3m=0; //crank up the ISRs #asm sei #endasm }
Zitieren
