Ergebnis 21 bis 30 von 38
Thema: My first programmable robot "WSTR1.3" [and videos]
    Bad Schussenried in Oberschwaben
    Hi!
    How long does the Bot work whith this giant power-reserve?
    Hm.
    best regards, Tobi
    http://www.tobias-schlegel.de
    "An AVR can solve (almost) every problem" - ts
    Hi, nice Bot!
    Mfg.techboy
    Error is your friend!
    Earth
    Hello,
    I’m not exactly sure but I think it is around 1,25 hours.
    Greetings,
    H.J. Windt
    Hi!
    Ah! not bad, not bad.
    Are these bearings of the two motors directly screwed (mounted ??) onto the plastic?
    best regards Tobi
    Earth
    Hello,
    The bearings are held in place with bearing blocks and the bearing blocks are mounted to the plastic using M3 rings, nuts and bolts.
    Greetings,
    H.J. Windt
    Deggendorf
    Yes its a nice one! Where did u get the Catweasel from?
    o00o----'(_)'----o00o
    mfg Solo
    Earth
    Hello,
    Here Bild   www.conrad.com Bild
    Greetings,
    H.J. Windt
    Earth
    Hello,
    I have not had very much time to work on my bot but I was able to make some short videos.
    The “Just Run” video shows the bot using a program to just ride around without hitting anything.
    https://www.roboternetz.de/phpBB2/dl...le&file_id=287
    The “Wall Hugger” video shows the bot using another program making the bot follow a wall on its right side trying to keep a certain distance from the wall.
    https://www.roboternetz.de/phpBB2/dl...le&file_id=288
    Greetings,
    H.J. Windt
  9. #29
    HI
    This is very good!
    You implimated the PWM (Pulse Width Modultaion ?? ) very well!
    How do you calculate the radien in the wall-following-algorithm, and how do you convert them into PWM?
    have fun,
    Tobi
  10. #30
    Earth
    Hello,
    The drive motors are connected to an MD22 (dual motor driver) and the C-Control communicates with the MD22 via my E-I2C bus.
    To control the motors the controller sends 3 bytes of information to the MD22 control registers (of course the address and command bytes ex. are also sent) and the MD22 does the rest.
    The bytes send are speed1 (drive speed right), speed2 (drive speed left) and acceleration.
    Speeds control the direction and speeds of the motors:
    0 = fast reverse…….128 = stop……..255 = fast forward
    Acceleration controls the pull up time:
    0 = pull up fast……………………….255 = pull up slowly.
    The Wall Hugger program only uses 3 scan angles and 4 movement directions:
    Scan angles:
    Forward scan (front): Stepper motor at position 50/ fire and read the SRF08
    Corner scan (front right): Stepper motor at position 35/ fire and read the SRF08
    Side scan (right side): Stepper motor at position 20/ fire and read the SRF08
    Movement directions:
    Turn left
    Bear left
    Forward
    Bear right
    No calculations are done, its just a few IF THEN’s and a few subroutines, but it would be very interesting to try calculation instead of the IF THEN’s .
    Here is also a portion of the Wall Hugger code.
    #start
    #front_scan
    steppermotor_start_position = 50 : gosub steppermotor_control
    gosub get_srf08_range
    if srf08_actual_range < 45 then goto turn_left
    #corner_scan
    steppermotor_start_position = 35 : gosub steppermotor_control
    if srf08_actual_range < 55 then goto bear_left
    #side_scan
    steppermotor_start_position = 20 : gosub steppermotor_control
    if srf08_actual_range < 45 then goto bear_left
    if srf08_actual_range < 55 then goto forward
    goto bear_right
    #turn_left
    drive_speed_right = 150
    drive_speed_left = 106
    drive_acceleration = 255
    gosub set_md22_speeds
    goto start
    #bear_left
    drive_speed_right = 170
    drive_speed_left = 144
    goto start
    #forward
    drive_speed_right = 160
    drive_speed_left = 160
    goto start
    #bear_right
    drive_speed_left = 170
    drive_speed_right = 144
    goto start
    Greetings,
    H.J. Windt
