Also irgendwie kommt immer nur noch Müll dabei raus. Das was jetzt dabei raus kommt macht irgendwie überhaupt keinen Sinn und ein Muster ist auch nicht zu erkennen:
Code:#define F_CPU 8000000 #define BAUD_RATE 9600 #include <avr/delay.h> #include <avr/interrupt.h> #include <avr/signal.h> #include <math.h> #include <stdlib.h> #include <string.h> #include <stdio.h> #include <avr/io.h> #include <avr/sfr_defs.h> #define stopsign '!' #define startsign '&' volatile char inStr[500]; volatile int inCnt = 0; // -- METHODEN DEKLARATIONEN void keep_moving(void); void move(int servo, int pos); void calc_steps(void); int putChar(char c); int signum(int val); void uart_init(int tx, int rx); uint8_t uart_readChar(void); void parseInput(void); void input(void); volatile uint8_t char_flag = 0; // -- SERVO VARIABLES volatile uint8_t servo_flag = 0; volatile float shoulder_pos = 127.0; volatile float elbow_pos = 127.0; volatile float wrist_pos = 127.0; volatile float gripper_pos = 127.0; volatile uint8_t shoulder_dest = 255; volatile uint8_t elbow_dest = 1; volatile uint8_t wrist_dest = 127; volatile uint8_t gripper_dest = 250; volatile float shoulder_step = 0; volatile float elbow_step = 0; volatile float wrist_step = 0; volatile float gripper_step = 0; int main (void) { //TIMER-IINTERRUPT AN TCCR0 |= (1<<CS01) | (1<<CS00); TIMSK |= (1<<TOIE0); //UART-INTERRUPT AN UCSRB |= (1<<RXCIE); //UART INITIALISIEREN (RX UND TX ANSCHALTEN) uart_init(1, 1); //GLOBAL INTERRUPT AN sei(); //PRINTF FÜR AUSGABE KONFIGURIEREN fdevopen(putChar,NULL,0); printf("\n\n\rSTART !!!\n\r"); //HAUPTSCHLEIFE while(1) { //NUR AUFRUFEN, WENN EIN TIMER INTERUPT DA WAR if(servo_flag == 1) { calc_steps(); keep_moving(); } if(char_flag == 1) { cli(); input(); sei(); } } return 0; } void parseInput(void) { // ANZAHL DER ZEICHEN: inCnt // INDEX DES LETZTEN ZEICHENS inCnt-1 cli(); printf("\n\rPARSING %s ...\n\r", inStr); int cnt = 0; if(inStr[0] == 's') { printf("SERVO COMMAND FOUND\n\r"); int hundreds = (int)inStr[2]-48; int tens = (int)inStr[3]-48; int ones = (int)inStr[4]-48; int number = hundreds*100 + tens*10 + ones; printf("NUMBER: %i\n\r", number); int servo = (int)inStr[1] - 48; switch(servo) { case(1): shoulder_dest = number; printf("\n\rSHOULDER_DEST CHANGED\n\r"); break; case(2): elbow_dest = number; printf("\n\rELBOW_DEST CHANGED\n\r"); break; case(3): wrist_dest = number; printf("\n\rWRIST_DEST CHANGED\n\r"); break; case(4): gripper_dest = number; printf("\n\rGRIPPTER_DEST CHANGED\n\r"); } } sei(); } void input(void) { inStr[inCnt] = uart_readChar(); switch (inStr[inCnt]) { case (stopsign): parseInput(); inCnt=0; break; case (startsign): inCnt=0; break; default: inCnt++; break; } char_flag = 0; } // -- METHODEN ZUM BEWEGEN DER Servos void keep_moving() { //CALCULATE NEW POSITIONS shoulder_pos = shoulder_pos + shoulder_step; elbow_pos = elbow_pos + elbow_step; wrist_pos = wrist_pos + wrist_step; gripper_pos = gripper_pos + gripper_step; //SET STEP=0 IF DEST. POSITION WAS REACHED if( (int)(shoulder_pos) == shoulder_dest){ shoulder_step = 0; } if( (int)(elbow_pos) == elbow_dest) { elbow_step = 0; } if( (int)(wrist_pos) == wrist_dest) { wrist_step = 0; } if( (int)(gripper_pos) == gripper_dest) { gripper_step = 0; } //POSITIONEN SCHICKEN move(1, (int)shoulder_pos); move(2, (int)shoulder_pos); move(3, (int)elbow_pos); move(4, (int)wrist_pos); move(5, (int)gripper_pos); printf("%c%c", 15, 17); printf("POSITION:\tSHOULDER:%i \tELBOW:%i \tWRIST:%i \t GRIPPER:%i\n\r", (int)shoulder_pos,(int)elbow_pos,(int)wrist_pos,(int)gripper_pos); servo_flag = 0; } void calc_steps(void) { float shoulder_to_go = shoulder_dest - shoulder_pos; float elbow_to_go = elbow_dest - elbow_pos; float wrist_to_go = wrist_dest - wrist_pos; float gripper_to_go = gripper_dest - gripper_pos; float shoulder_absolute = abs(shoulder_to_go); float elbow_absolute = abs(elbow_to_go); float wrist_absolute = abs(wrist_to_go); float gripper_absolute = abs(gripper_to_go); shoulder_step = 1; elbow_step = 1; wrist_step = 1; gripper_step = 1; //GET GREATEST VALUE uint8_t largest_way_servo = shoulder_absolute; if(elbow_absolute > largest_way_servo) { largest_way_servo = elbow_absolute; } if(wrist_absolute > largest_way_servo) { largest_way_servo = wrist_absolute; } if(gripper_absolute > largest_way_servo) { largest_way_servo = gripper_absolute; } //SET STEP DEPENDING ON GREATEST VALUE (BIGGEST STEP=1) shoulder_step = (shoulder_absolute/largest_way_servo) * signum(shoulder_to_go); elbow_step = (elbow_absolute/largest_way_servo) * signum(elbow_to_go); wrist_step = (wrist_absolute/largest_way_servo) * signum(wrist_to_go); gripper_step = (gripper_absolute/largest_way_servo) * signum(gripper_to_go); } void move(int servo, int pos){ loop_until_bit_is_set(UCSRA, UDRE); UDR = '#'; loop_until_bit_is_set(UCSRA, UDRE); UDR = 's'; loop_until_bit_is_set(UCSRA, UDRE); UDR = servo; loop_until_bit_is_set(UCSRA, UDRE); UDR = pos; } //SIGNUM WIRD NUR IN calc_steps BENÖTIGT int signum(int val) { if(val != 0) { return val/abs(val); } else { return 0; } } //INTERRUPTS SIGNAL (SIG_OVERFLOW0){ servo_flag = 1; } SIGNAL(SIG_USART_RECV) { char_flag = 1; } // -- UART METHODEN void uart_init(int tx, int rx) { UBRRL = (F_CPU/(BAUD_RATE*16l)-1); if(tx == 1) { UCSRB |= (1<<TXEN); } if(rx == 1) { UCSRB |= (1<<RXEN); } } int putChar(char c){ while ( !( UCSRA & (1<<UDRE)) ); UDR=c; return 0; } uint8_t uart_readChar(void) { return UDR; }
Zitieren
