Ergebnis 11 bis 17 von 17
Thema: Leaving Programing mode STK500 beim brennen vom ATmega8???
    Sowas hatte ich bis jetzt 2 mal. Lies sich beheben, indem ich beim STK die Firm neu programmiert hab.
    Rainer
    Danke Rainer,
    kannst du mir noch sagen wie ich die Firm neu Programmier, oder
    wo ich das genau nachlesen kann?
    Gruß Wasi...
    Aktuelles AVRStudio von Atmel laden, installieren.
    Der Rest steht in der Hilfe unter STK500 Manual Firmware Upgrade:
    The current version of AVR Studio will automatically detect any old STK500 firmware version and request the user to upgrade the firmware. If for some reason the upgrade fails (the serial cable is detached during upgrade, the power goes out, ...) the next time the AVR Studio tries to connect to the STK500, the board will not be detected and the automatic upgrade procedure will not start.
    Following is a procedure on how to manually upgrade a STK500 board. This procedure should work in all cases:
    Power off the STK500
    Push the 'PROGRAM' button (located near the AT45D021 dataflash) while powering up the STK500
    Start AVR Studio and make sure there is a serial connection between the PC and the STK500 DSUB9 marked 'RS232 CTRL'
    Start the program 'Avr Prog' located in the AVR Studio 'Tools' menu
    Locate the firmware upgrade hex-file 'stk500.ebn' by pushing the 'Browse'-button in the 'Avr Prog Hex File'-window. The path for the 'stk500.ebn' for a normal AVR Studio installation is "C:\Program Files\Atmel\AVR Tools\STK500".
    Push the 'Program'-button in the 'Avr Prog Flash'-window. A progress bar will now appear while showing additional information messages. Wait until the verify operation is finished.
    Close the 'Avr Prog' program
    Power off and on the STK500 PCB. The STK500 is now ready to be used with the new firmware.
    Keine Ahnung, ob´s noch ne andere Möglichkeit gibt ohne AVRStudio.
    Rainer
    Danke Rainer!
    Werd ich wohl machen müßen, verwende sowieso das AVRStudio.
    Gruß Wasi...
    Hab soeben das Update gemacht und Funktioniert wieder Prima!
    Danke für die Mitteilung deiner Erfahrung!
    Gruß Wasi...
    Reading FLASH input file.. OK
    Setting mode and device parameters.. OK!
    Entering programming mode.. OK!
    Reading FLASH .. FAILED!
    Leaving programming mode.. FAILED!
    ... selbige Fehlermeldung bekommst Du auch, wenn im AVR-Programmer die ISP-Frequenz zu hoch eingestellt hast -> irgendwie wird diese bei mir hin und wieder verstellt (bis ich dahinter kam...)
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken avr.gif
    Neuer Benutzer Öfters hier Avatar von mattmiksys
    Wohltorf/Hamb.
    Der Rest steht in der Hilfe unter STK500 Manual Firmware Upgrade...
    Supie, das hat mich gerade gerettet! Ich hatte aber auch nicht damit gerechnet, dass sich die Firmware des STK-Chips von einem Moment zum anderen verändert, so erst alles mögliche andere probiert. Weiter gehts ...
    Grüße,
    Matthias
    Die Seele jeder Ordnung ist ein großer Papierkorb (Tucholsky)
