Guter Einwurf, war ein Fehler.
Doch nun erhalte ich den vorherigen Fehler (Error 60 , 60 und 221) mit dem Code:
Veränderung der Stack Werte bzw. framesize beheben leider nicht den Fehler.Code:$regfile = "m32def.dat" $framesize = 32 $swstack = 256 $hwstack = 128 $crystal = 16000000 $baud = 9600 $lib "mcsbyte.lbx" Config Pind.6 = Input Config Rc5 = Pind.6 Portd.6 = 1 Config Pinc.2 = Output Config Pinc.4 = Output Config Pinc.3 = Input 'Ports für linken Motor Config Pinb.0 = Output Config Pinb.4 = Output Config Pind.5 = Output 'Ports für rechten Motor Config Pinb.1 = Output Config Pinb.2 = Output Config Pind.4 = Output Config Servos = 2 , Servo1 = Portd.7 , Servo2 = Portb.3 , Reload = 10 Config Pinb.3 = Output Config Pind.7 = Output Enable Interrupts Dim Address As Byte , Command As Byte Dim Pulses As Word , Periods As Word Pulses = 65535 : Periods = 10000 Speaker Alias Portc.2 Dim I As Integer Declare Sub Vorwaerts Declare Sub Rueckwaerts Declare Sub Halt Declare Sub Links Declare Sub Rechts Declare Sub These Declare Sub Camera Do Portc.4 = 1 Gosub Camera Gosub Vorwaerts Loop Sub Camera Servo(2) = 95 Print "Mittelstellung" Wait 1 Servo(1) = 95 Print "Mittelstellung" Wait 1 End Sub Return Sub Vorwaerts Do Portb.1 = 1 Portb.2 = 0 Portb.4 = 0 Portb.0 = 1 Portd.4 = 1 Portd.5 = 1 Getrc5(address , Command) Loop Until Pinc.3 = 0 Or Command = 11 Or Command = 12 Or Command = 13 Or Command = 14 Or Command = 15 Gosub Halt End Sub Return Sub Halt Portb.1 = 1 Portb.2 = 1 Portb.4 = 1 Portb.0 = 1 Portd.4 = 1 Portd.5 = 1 Wait 1 Getrc5(address , Command) Waitms 150 If Command = 11 And Command = 12 And Command = 13 And Command = 14 And Command = 15 Or Command = 12 And Command = 13 And Command = 14 Then Gosub Rueckwaerts Elseif Command = 11 Or Command = 12 Then Gosub Rechts Elseif Command = 13 Or Command = 14 Or Command = 15 Then Gosub Links Elseif Command = 255 Then Gosub These End If End Sub Return Sub Rueckwaerts Portb.1 = 0 Portb.2 = 1 Portb.4 = 1 Portb.0 = 0 Portd.4 = 1 Portd.5 = 1 Waitms 500 Portb.1 = 1 Portb.2 = 1 Portb.4 = 1 Portb.0 = 1 Portd.4 = 1 Portd.5 = 1 Waitms 500 Gosub Rechts End Sub Return Sub Rechts Portb.1 = 1 Portb.2 = 0 Portb.4 = 1 Portb.0 = 0 Portd.4 = 1 Portd.5 = 1 Waitms 500 Gosub Vorwaerts End Sub Return Sub Links Portb.1 = 0 Portb.2 = 1 Portb.4 = 0 Portb.0 = 1 Portd.4 = 1 Portd.5 = 1 Waitms 500 Gosub Vorwaerts End Sub Return Sub These Portb.1 = 1 Portb.2 = 0 Portb.4 = 1 Portb.0 = 0 Portd.4 = 1 Portd.5 = 1 Waitms 500 Gosub Vorwaerts End Sub Return End
Zitieren
