Seite 5 von 5 ErsteErste ... 345
Ergebnis 41 bis 43 von 43
Thema: mal wieder ne Änfängerfrage: Strings
  1. #41
    Obertraun
    gehts so nicht?
    # makefile, written by guido socher
    MCU=atmega32
    CC=avr-gcc
    OBJCOPY=avr-objcopy
    # optimize for size:
    CFLAGS=-g -mmcu=$(MCU) -Wall -Wstrict-prototypes -Os -mcall-prologues
    all: test.hex
    help:
       @echo "Usage: make all|load|load_pre|rdfuses|wrfuse1mhz|wrfuse4mhz|wrfusecrystal"
       @echo "Warning: you will not be able to undo wrfusecrystal unless you connect an"
       @echo "         external crystal! uC is dead after wrfusecrystal if you do not"
       @echo "         have an external crystal."
    test.hex : test.out
       $(OBJCOPY) -R .eeprom -O ihex test.out test.hex
    test.out : test.o
       $(CC) $(CFLAGS) -o test.out -Wl,-Map,test.map test.o -lm
    test.o : test.c
       $(CC) $(CFLAGS) -Os -c test.c
    load: test.hex
       ./prg_load_uc test.hex
    # here is a pre-compiled version in case you have trouble with
    # your development environment
    load_pre: test_pre.hex
    loaduisp: test.hex
       ./prg_load_uc -u test.hex
    load_preuisp: test_pre.hex
    # fuse byte settings:
    #  Atmel AVR ATmega8
    #  Fuse Low Byte      = 0xe1 (1MHz internal), 0xe3 (4MHz internal), 0xe4 (8MHz internal)
    #  Fuse High Byte     = 0xd9
    #  Factory default is 0xe1 for low byte and 0xd9 for high byte
    # Check this with make rdfuses
    rdfuses:
       ./prg_fusebit_uc -r
    # use internal RC oscillator 1 Mhz
    wrfuse1mhz:
       ./prg_fusebit_uc -w 1
    # use internal RC oscillator 4 Mhz
    wrfuse4mhz:
       ./prg_fusebit_uc -w 4
    # use external 3-8 Mhz crystal
    # Warning: you can not reset this to intenal unless you connect a crystal!!
    wrfusecrystal:
       @echo "Warning: The external crystal setting can not be changed back without a working crystal"
       @echo "         You have 3 seconds to abort this with crtl-c"
       @sleep 3
       ./prg_fusebit_uc -w 0
    clean:
       rm -f *.o *.map *.out *t.hex
  2. #42
    JUHUUUUUUU! Jetzt gehts. Du hast mir aber vorhin die falsche Zeile gesagt an die ich das anhängen soll. Du hast die darunter angegeben.
    neja, das wäre jetzt jedefalls gelöst.
    Danke für die Mühe und die Ausdauer !!!
    jagdfalke
  3. #43
    Obertraun
    na Endlich! Bild
