Ergebnis 1 bis 3 von 3
Thema: 4x 7Segment mit multiplex und NUR 5 ausgängen
    So hab mal wieder n paar fragen:
    ich möchte wie der titel ja schon sagt eine 4 stellige 7 segment anzeige mittels multiplexverfahren ansteuern.
    hab jetzt schon ziemlich viel darüber gelesen aber das beste beispiel ist glaub ich das in den sampels von proteus.
    Tiny 15 - Test of ADC - also include multiplex display driver.
    ; Specify Device.
    .device ATTINY15
    ; I/O Register Definitions
    .equ    SREG    =$3F
    .equ    GIMSK   =$3B
    .equ    GIFR    =$3A
    .equ    TIMSK   =$39
    .equ    TIFR    =$38
    .equ    MCUCR   =$35
    .equ    TCCR0   =$33
    .equ    TCNT0   =$32
    .equ    TCCR1   =$30
    .equ    TCNT1   =$2F
    .equ    OCR1A   =$2E
    .equ    OCR1B   =$2D
    .equ    PORTB   =$18
    .equ	DDRB	=$17
    .equ    ACSR    =$08
    .equ    ADMUX   =$07
    .equ    ADCSR   =$06
    .equ    ADCH    =$05
    .equ    ADCL    =$04
    ; Variable Declarations
    .def temp     = r16
    .def isrsreg  = r18
    .def isrtemp1 = r19
    .def isrtemp2 = r20
    .def cseg     = r21
    .def seg0     = r22
    .def seg1     = r23
    .def seg2     = r24
    .def seg3     = r25
    .cseg					; CODE segment.
    ;Interrupt Vectors
    .org 0
    	rjmp init			;Reset
    	reti				;INT 0
    	reti				;Pin Change
    	reti				;Output compare
    	reti				;Timer 1
    	rjmp tov0			;Timer 0
    	reti				;EEPROM ready
    	reti				;Analog Comparator
    	reti				;ADC Complete
    ;Initialization
    init:   ldi r16,$1F		; 5 bits are outputs
    	out DDRB,r16   		; set portb bit 0 for outputs to display
    	ldi r16,3		; Timer 0 rolls over at 1.6MHz/256/64 = 97Hz
    	out TCCR0,r16
    	ldi r16,$02		; Enable TOVF0
    	out TIMSK,r16
    	ldi cseg,$01		; Start at segment
    	sei			; Enable Interrupts
    	ldi r16,$8E		; Enable, ADIE, Prescale = 1/64
    	out ADCSR,r16
    	ldi r16,0		; Select ADC0 as input, VCC as VREF
    	out ADMUX,r16
    loop:	ldi r16,$20		; Sleep enable, idling mode
    	out MCUCR,r16
    	sleep			; Wait for a timer 0 interrupt
    	cpi cseg,8		; Wait for write to MS segment
    	breq loop
    	ldi r16,$28		; Sleep enable, ADC low noise mode
    	out MCUCR,r16
    	sleep			; Wait for ADC to convert
    	in r0,ADCL		; Read the converted value
    	in r1,ADCH
    ;Convert and display value for output
    ;Start value taken to be in r1:r0
    	clr r4			;Count result
    dc1a:	mov r2,r0		;Subtract 1000's
    	mov r3,r1
            ldi r16,$e8
            sub r2,r16
            ldi r16,$3
            sbc r3,r16
            brcs dc1b
        	inc r4
        	mov r0,r2
        	mov r1,r3
        	rjmp dc1a		; Go again
    dc1b:   mov seg0,r4		; Store result
    	clr r4
    dc2a:	mov r2,r0		;Subtract 100's
    	mov r3,r1
            ldi r16,100
            sub r2,r16
            clr r16
            sbc r3,r16
            brcs dc2b
        	inc r4
        	mov r0,r2
        	mov r1,r3
        	rjmp dc2a		; Go again
    dc2b:   mov seg1,r4		; Store result
    	clr r4
    dc3a:	mov r2,r0		;Subtract 10's
            ldi r16,10
            sub r2,r16
            brcs dc3b
        	inc r4
        	mov r0,r2
        	rjmp dc3a		; Go again
    dc3b:   mov seg2,r4		; Store result
    	mov seg3,r0    		; The units are trivial
    	rjmp loop		; Go again
    ;Timer 0 interrupt - display driver
    tov0:	in isrsreg,SREG		; Preserver sreg
    	clr isrtemp1		; Blank the display
    	out PORTB,isrtemp1
    	lsr cseg		; Advance segment selector address
    	brcc tov0_1
    	ldi cseg,0x08		; Reset to seg 3
    tov0_1: out PORTB,cseg		; Drive the latch
    	sbrc cseg,3		; Select byte to output
    	mov isrtemp1,seg3
    	sbrc cseg,2
    	mov isrtemp1,seg2
    	sbrc cseg,1
    	mov isrtemp1,seg1
    	sbrc cseg,0
    	mov isrtemp1,seg0
    	ldi isrtemp2,$10	;Bit 4 is set to enable the 7447
    	or isrtemp1,isrtemp2
    	sbi PORTB,4		;Pre Assert PB4
    	out PORTB,isrtemp1	;Drive the segment value onto the display
    	out SREG,isrsreg
    	reti
    hier wird das eigentliche "datensignal" und die auswahl der anzeige mit nur 5 pins erreicht dh datensignal und steuersignal sind gemischt. Dementsprechend find ich die programmierung schwierig.
    kann mir mal irgendjemand den asm code in verständliches C übersetzen?
    oder mir verständlich machen wie ich dieses "muster" ausgebe?
    im anhang seht ihr das datensignal wenn 0001 ausgegeben wird(von oben: PINB0 , PINB1 , PINB2 , PINB3 , dann 3 pins des signals hinterm d-flipflop, und PINB4 also clock)
    so hab da mal angefangen nen code zammen zu basteln und zwar gehts mir um die erste ziffer also hier mal das ganze um eine 0 zu übertragen:
    include <stdio.h>
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <avr/signal.h>
    #include <math.h>
    #include <avr/delay.h>
    int main(void);
    char Convert2PacketBCD(char value);
    SIGNAL (SIG_OUTPUT_COMPARE0)
    char temp1;
    		PORTB=0b00000000;
    		PORTB=0b10000001;
    		temp1=Convert2PacketBCD(0x00);
    		temp1&=0x0F;
    		temp1|=0b10000000;
    		PORTB = temp1;
         unsigned char result;
         result = value % 10;
         result += (value - result)/10 * 0x10;
         return result;
    int main(void) {
    	DDRB =0xff;
    	PORTB=0x00;
    	TCCR0= 0x02;
    	TIMSK=0x02;
    	sei();
    	while (1) {
    	return 0;
    wieso bekomme ich innerhalb der int routine schon 2 pulse??? also ganz unten ist mein clock. naja bekomm zwar ne null allerdings auch noch ne 1 wegen den pulsen
    na bin für jede menge anregungen dankbar
    antworten kann ich heut leider nicht mehr höchstens zu später stunde..
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken mylogic.jpg   multiplex_logic.jpg   multiplex_circuit.jpg
    An der Saar
    Das asm nach C zu 'übersetzen' und aufzudröseln ist IMHO mehr Arbeit als sich anzuschauen, welche Signale die Schaltung haben will und ihr diese zu geben.
    B4 wählt aus zwischen 174 (D-Latch) und 47 (DCB-Dekoder/LED-Treiber). Die einzelnen Displays sind mit gemeinsamer Anode wie's aussieht. Der 174 geht wohl weiter zu 4 Anodentreibern.
    Je nach B4 landen die Daten B0 bis B3 einmal direkt am 47 und einmal an dein Eingängen des 174.
    Beim Wegschalten vom 174 zum 47 gibt's ne Flanke am 174.CLK und die 4 Bits werden in dessen Latches übernommen.
    Gleichzeitig ist der 47 OFF so daß am Display nix zuckelt. Ist der 47 aktiv, dann dat der 174 seine Daten im Latch und wird durch die am Eingang anliegenden Werte nicht behelligt.
    That's it.
    An den 47 legst du den anzuzeigenden Wert und an den 174 welches Display jeweils diesen Wert zeigen soll.
    Disclaimer: none. Sue me.
    ja war gar ned so schwer habs zwar n bissl anders gelöst als die das im assembler gemacht haben aber es funzt auch so..
