Code:'Testprogramm 'Baugruppe: 'Schrittmotor-Interface für die C-Control '-----Unipolare-Ansteuerung------ '------Für AEG SO26/48------------ '--48 Schritte = 1 Umdrehung-- 'Treiber IC: L298N ' an jedem Output 1 Diode (Bo580) 'Phasenbelegung am IC: 'Out1 -->-Phase 3 'Out2 -->-Phase 4 'Out3 -->-Phase 1 'Out4 -->-Phase 2 'M1 Rechts / M2 Links Define MotorPort BytePort[1] 'Digitalausgänge für die Motoren A Define MotA1 Port[13] 'Motor A - Phase 1 Define MotA2 Port[11] 'Motor A - Phase 2 Define MotA3 Port[14] 'Motor A - Phase 3 Define MotA4 Port[12] 'Motor A - Phase 4 Define MotB1 Port[10] 'Motor A - Phase 1 Define MotB2 Port[16] 'Motor A - Phase 2 Define MotB3 Port[9] 'Motor A - Phase 3 Define MotB4 Port[15] 'Motor A - Phase 4 'M1 und M2 VOR 'zum aktivieren alle Oberpunkte entfernen und bei der anderen Definition eingeben. 'Define MotorPort BytePort[1] 'Digitalausgänge für die Motoren A 'Define MotA1 Port[13] 'Motor A - Phase 1 'efine MotA2 Port[11] 'Motor A - Phase 2 'Define MotA3 Port[14] 'Motor A - Phase 3 'Define MotA4 Port[12] 'Motor A - Phase 4 'Define MotB1 Port[15] 'Motor A - Phase 1 'Define MotB2 Port[9] 'Motor A - Phase 2 'Define MotB3 Port[16] 'Motor A - Phase 3 'Define MotB4 Port[10] 'Motor A - Phase 4 'Schleife zum test---------jeweils 1 halbe Umdrehung wechselnd an 2 Motoren : #Schleife MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = ON MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = ON MotA2 = OFF MotA3 = OFF MotA4 = OFF Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = OFF MotA4 = ON Pause 6 MotA1 = OFF MotA2 = OFF MotA3 = ON MotA4 = OFF Pause 1 MotB1 = OFF MotB2 = ON MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = ON MotB2 = OFF MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = OFF MotB4 = ON Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = ON MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = ON MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = ON MotB2 = OFF MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = OFF MotB4 = ON Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = ON MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = ON MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = ON MotB2 = OFF MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = OFF MotB4 = ON Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = ON MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = ON MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = ON MotB2 = OFF MotB3 = OFF MotB4 = OFF Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = OFF MotB4 = ON Pause 6 MotB1 = OFF MotB2 = OFF MotB3 = ON MotB4 = OFF Pause 6 GoTo Schleife 'F**K YOU!
vieleicht hilft es ja irgendwann mal jemanden...
Zitieren
