Wieso kriege ich denn Fehler?
BYVAL should be used in declaration [[112]]
Code:Declare Sub Leftdir(ddir As Bit) Declare Sub Rightdir(ddir As Bit) If Command = 17 Then Call Leftdir(1) End If If Command = 16 Then Call Rightdir(1) End If Sub Leftdir(ddir As Bit) If Ddir = 0 Then Portb.0 = 1 Portb.1 = 0 Portb.2 = 0 Portb.3 = 0 Else Portb.0 = 0 Portb.1 = 1 Portb.2 = 0 Portb.3 = 0 End If End Sub Sub Rightdir(ddir As Bit) If Ddir = 0 Then Portb.0 = 0 Portb.1 = 0 Portb.2 = 0 Portb.3 = 1 Else Portb.0 = 0 Portb.1 = 0 Portb.2 = 1 Portb.3 = 0 End If End Sub
Zitieren
