Ergebnis 11 bis 18 von 18
Thema: Tastatur einbinden und Werte hochzählen
    ich habe da mal ein kleines Programm mit LED's geschrieben und dabei incr benutzt.
    Nur arbeitet das Programm nicht alles nacheinander ab, sondern abwechselnd, bin mir sicher, dass es an den < und > liegt
    Hier mein Programm:
      $regfile = "m32def.dat"
     ' $framesize = 32
      '$swstack = 32
      '$hwstack = 32
      $crystal = 16000000
      $baud = 9600
    '--------LED-----------
    Config Porta = Output
    '--------Taster--------
    Config Pinb.0 = Input
    Portb.0 = 1
    Declare Sub Lauflicht
    Declare Sub Allean
    Declare Sub Nacheinander
    Declare Sub Startrek
    Dim Anzahl As Byte
    Do
       If Pinb.0 = 1 Then
    Incr Anzahl
    If Anzahl < 25 Then Gosub Lauflicht
    If Anzahl > 25 Then Gosub Allean
    If Anzahl > 50 Then Gosub Nacheinander
    If Anzahl < 50 Then Gosub Startrek
    If Anzahl = 75 Then Anzahl = 0
    End If
    Loop
    Sub Startrek
       Print "Star Trek"
       Porta.0 = 1
       Porta.6 = 1
       Waitms 150
       Porta.0 = 0
       Porta.6 = 0
       Porta.1 = 1
       Porta.5 = 1
       Waitms 150
       Porta.1 = 0
       Porta.5 = 0
       Porta.2 = 1
       Porta.4 = 1
       Waitms 150
       Porta.4 = 0
       Porta.2 = 0
       Porta.3 = 1
       Waitms 150
       Porta.3 = 0
       Waitms 150
       End Sub
       Return
    Sub Lauflicht
       Print "Lauflicht"
       Porta.0 = 1
       Waitms 40
       Porta.0 = 0
       Porta.1 = 1
       Waitms 40
       Porta.1 = 0
       Porta.2 = 1
       Waitms 40
       Porta.2 = 0
       Porta.3 = 1
       Waitms 40
       Porta.3 = 0
       Porta.4 = 1
       Waitms 40
       Porta.4 = 0
       Porta.5 = 1
       Waitms 40
       Porta.5 = 0
       Porta.6 = 1
       Waitms 40
       Porta.6 = 0
       Porta.5 = 1
       Waitms 40
       Porta.5 = 0
       Porta.4 = 1
       Waitms 40
       Porta.4 = 0
       Porta.3 = 1
       Waitms 40
       Porta.3 = 0
       Porta.2 = 1
       Waitms 40
       Porta.2 = 0
       Porta.1 = 1
       Waitms 40
       Porta.1 = 0
       End Sub
       Return
    Sub Allean
       Print "alle an"
       Porta.0 = 1
       Porta.1 = 1
       Porta.2 = 1
       Porta.3 = 1
       Porta.4 = 1
       Porta.5 = 1
       Porta.6 = 1
       Waitms 250
       End Sub
       Return
    Sub Nacheinander
           Print "1.Led "
           Porta.0 = 1
           Porta.1 = 0
           Porta.2 = 0
           Porta.3 = 0
           Porta.4 = 0
           Porta.5 = 0
           Porta.6 = 0
           Waitms 100
           Print "2.Led "
           Porta.0 = 0
           Porta.1 = 1
           Porta.2 = 0
           Porta.3 = 0
           Porta.4 = 0
           Porta.5 = 0
           Porta.6 = 0
           Waitms 100
           Print "3.Led "
           Porta.0 = 0
           Porta.1 = 0
           Porta.2 = 1
           Porta.3 = 0
           Porta.4 = 0
           Porta.5 = 0
           Porta.6 = 0
           Waitms 100
           Print "4.Led "
           Porta.0 = 0
           Porta.1 = 0
           Porta.2 = 0
           Porta.3 = 1
           Porta.4 = 0
           Porta.5 = 0
           Porta.6 = 0
           Waitms 100
           Print "5.Led "
           Porta.0 = 0
           Porta.1 = 0
           Porta.2 = 0
           Porta.3 = 0
           Porta.4 = 1
           Porta.5 = 0
           Porta.6 = 0
           Waitms 100
           Print "6.Led "
           Porta.0 = 0
           Porta.1 = 0
           Porta.2 = 0
           Porta.3 = 0
           Porta.4 = 0
           Porta.5 = 1
           Porta.6 = 0
           Waitms 100
           Print "7.Led "
           Porta.0 = 0
           Porta.1 = 0
           Porta.2 = 0
           Porta.3 = 0
           Porta.4 = 0
           Porta.5 = 0
           Porta.6 = 1
           Waitms 100
           End Sub
           Return
    End
    Ich habe es auch mit versch. incr versucht, aber das gleiche Problem erhalten:
    Declare Sub Allean
    Dim A As Byte
    Dim B As Byte
    Dim C As Byte
    Dim D As Byte
    Do
       If Pinb.0 = 1 Then
    Incr A
    If A < 10 Then Gosub Lauflicht
    Incr B
    If B < 10 Then Gosub Allean
    Incr C
    If C < 10 Then Gosub Nacheinander
    Incr D
    If D < 10 Then Gosub Startrek
    Habt ihr Lösungsvorschläge oder Tipps, was ich falsch gemacht habe, bin echt dankbar.
    Ich bekomme es nicht hin, dass das Unterprogramm "Nacheinander" hinter dem "Allean" und dahinter "Startrek" wirklich abgeschlossen für sich läuft.
    Das einzigste gute daran: unkontrolliertes Software Multitasking, aber Multitasking
    Zu meinem Verständnis:
    1) Am Anfang tut sich mal nix.
    2)Du drückst auf die Taste-->Jetzt läuft ständig "Lauflicht"
    3)nochmal drücken --> "alle an"
    4)nochmal drücken --> "Nacheinander"
    5)nochmal drücken --> "Startrek"
    6)nochmal drücken --> --> 1)
    Ist das so gemeint ?
    mfg robert
    Ne, wäre aber schön, wenn es so wäre, läuft aber alles ab, obwohl der Taster nicht gedrückt worden ist (=1) und nicht wieder gedrückt wird.
    Zum Ablauf:
    '---------Lauflicht läuft--------------
    '--------Lauflicht ist aus, doch jetzt läuft alles durcheinander bzw. abwechselnd, denn ich kann nicht eindeutig im Programm schreiben: until = 50 zum Beispiel
    Hab mich schlecht ausgedrückt. Ich meinte, ob es so sein SOLL ?
    Ich weiß nicht, wie du das meinst, mit dem Hochzählen von Anzahl bis 75 ?
    Du hast doch nur 5 Zustände (=anzahl Tastendruck)
    Dann muß deine Schleife aus zwei Teilen bestehen:
    1) Soll sich der Zustand ändern ? (Tastenabfrage)
    2) das tun, was gerade anliegt.
    bei 1) kanst du nicht reagieren, WÄHREND die Taste gedrückt ist, sondern nur, wenn sich was ÄNDERT.
    (sonst ratterst du durch alle sub's, solange du den Finger auf der Taste
    hast. )
    'du brauchst noch ein Feld
    DIM tastealt as byte
    ' Abfrage in der schleife (Das debouncing ignorier' ich mal)
       if pinb.0 = 1 and tastealt.0 = 0 then
                incr zustand
    ' also nur, wenn die Taste von "NICHT GEDRÜCKT" auf "GEDRÜCKT" wechselt
       end if
       tastealt =   pinb  ' so oder so merken
    2)
     select case zustand
     case 0:     ' nix
     case 1:   gosub lauflicht
     case 2:  gosub allean
     case 3:  gosub nacheinander
     case 4:  gosub startrek
     case else:
                 zustand = 0   ' wieder von vorn
     end select
    Deine Subs dürfen natürlich keine Dauerschleifen sein, sie müssen immer wieder zurückkommen
    mfg robert
    Danke dir vielmals,
    es funktioniert \/
    Declare Sub Allean
    Dim Zustand As Byte
    Do
                Incr Zustand
    end if
       Tastealt = Pinb
     select case zustand
     case 0:     ' nix
     Case 1 : Gosub Lauflicht
     case else:
     end select
    Nur werde ich daraus:
                Incr Zustand
    end if
       Tastealt = Pinb
    nicht richtig schlau.
    Danke dir vielmals,
    es funktioniert \/
    Declare Sub Allean
    Dim Zustand As Byte
    Do
                Incr Zustand
    end if
       Tastealt = Pinb
     select case zustand
     case 0:     ' nix
     case else:
     end select
                Incr Zustand
    end if
       Tastealt = Pinb
    Einmal hätt's auch genügt.
    Schau: tastealt ist immer der Tastenzustand vorher, nach der Prüfung wird der aktuelle Zustand dort reingestellt. beim nächsten mal wird dann damit verglichen
    reagiert wird nur in dem Moment, wo die Taste VORHER noch offen war, und JETZT aber gedrückt ist. (=steigende Flanke=rising, =Low-High Übergang)
    Alle anderen Zustände
    ALT.........................NEU
    gedrückt --> gedrückt
    gedrückt ---> losgelassen
    nicht gedrückt ---> nicht gedrückt
    interessieren uns nicht.
    mfg robert
    Danke vielmals
    Der Doppelpost ist ungewollt, wenn ich einen Post reinsetze, bekomme ich immer eine Fehlerseite (aber im hintergrund ist immernoch die Option für reinsetzen aktiv), also wenn ich da 2 mal auf return komme.... Ich weiß nicht, ob es an der Seite liegt oder aber am Browser (glaub eher letzteres).
