Ich bekomme folgende Firmware nicht compiled! Kann mir jemand helfen? Bascom schmeisst den fehler aus: File not Found (???)
PS: Ich bin nicht der Beste Coder, is mein erstes projekt!
Ich danke im VorrausCode:'Mikrokontroller Schalter Per UART' 'by RaIdeN7400 ' 'Schaltet 8 Relais per UART oder 4 Schalter an/aus' 'V1.0' $regfile = "2313def.dat" $crystal = 3686400 $baud = 9600 Dim I As Byte Dim An As Integer Dim Aus As Integer Ddrd = &B00100000 Ddrb = &B11111111 On Urxc Onrxd Enable Urxc Enable Interrupts Main: If Pind.3 = 1 Then Portb.1 = 1 End If If Pind.4 = 1 Then Portb.2 = 1 End If If Pind.5 = 1 Then Portb.3 = 1 End If If Pind.6 = 1 Then Portb.4 = 1 End If Goto Main Onrxd: Portd.2 = 1 I = Udr Select Case I Case "switch 1" Toggle Portb.0 Print "Switched PortB.0!" Case "switch 2" Toggle Portb.1 Print "Switched PortB.1!" Case "switch 3" Toggle Portb.2 Print "Switched PortB.2!" Case "switch 4" Toggle Portb.3 Print "Switched PortB.3!" Case "switch 5" Toggle Portb.4 Print "Switched PortB.4!" Case "switch 6" Toggle Portb.5 Print "Switched PortB.5!" Case "switch 7" Toggle Portb.6 Print "Switched PortB.6!" Case "switch 8" Toggle Portb.7 Print "Switched PortB.7!" Case "about" Print "Relais Firmware V1.0 By RaIdeN" Case "help" Print "Du kannst PortB.0 - 7 per Command switch 1 - 8 an/ausschalten!" Print "Unter status kannst du sehen,welche Ports an und aus sind!" Case "status" An = "An sind: " Aus = "Aus sind: " If Pinb.0 = 1 Then An = An + "1 " Else Aus = Aus + "1 " End If If Pinb.1 = 1 Then An = An + "2 " Else Aus = Aus + "2 " End If If Pinb.2 = 1 Then An = An + "3 " Else Aus = Aus + "3 " End If If Pinb.3 = 1 Then An = An + "4 " Else Aus = Aus + "4 " End If If Pinb.4 = 1 Then An = An + "5 " Else Aus = Aus + "5 " End If If Pinb.5 = 1 Then An = An + "6 " Else Aus = Aus + "6 " End If If Pinb.6 = 1 Then An = An + "7 " Else Aus = Aus + "7 " End If If Pinb.7 = 1 Then An = An + "8 " Else Aus = Aus + "8 " End If Printbin An Printbin Aus Case Else Print "Unbekannter Befehl! Probier Mal help" End Select Wait 2 Return![]()
Zitieren
