Ergebnis 1 bis 3 von 3
Thema: SIGNAL (SIG_ADC) umsetzen in bascom
    wie kann man die interruptroutine für den adc "SIGNAL (SIG_ADC)" in Bascom umsetzen.
    mfg pebisoft
    '                  ADC_INT.BAS
    '  demonstration of GETADC() function in combintion with the idle mode
    '  for a better noise immunity
    '  Getadc() will also work for other AVR chips that have an ADC converter
    $regfile = "4433def.dat"
    $crystal = 4000000
    $baud = 19200
    'configure single mode and auto prescaler setting
    'The single mode must be used with the GETADC() function
    'The prescaler divides the internal clock by 2,4,8,16,32,64 or 128
    'Because the ADC needs a clock from 50-200 KHz
    'The AUTO feature, will select the highest clockrate possible
    Config Adc = Single , Prescaler = Auto
    'Now give power to the chip
    On Adc Adc_isr Nosave
    Enable Adc
    Enable Interrupts
    Dim W As Word , Channel As Byte
    Channel = 0
    'now read A/D value from channel 0
    Do
      Channel = 0
      'idle will put the micro into sleep.
      'an interrupt will wake the micro.
      Start Adc
      Idle
      Stop Adc
      Print "Channel " ; Channel ; " value " ; W
      Waitms 500
    Loop
    End
    Adc_isr:
      push r24
      in r24,sreg
      push r24
      push r25
      W = Getadc(channel)
      pop r25
      pop r24
      !out sreg,r24
      pop r24
    Return
    'The new M163 has options for the reference voltage
    'For this chip you can use the additional param :
    'Config Adc = Single , Prescaler = Auto, Reference = Internal
    'The reference param may be :
    'OFF      : AREF, internal reference turned off
    'AVCC     : AVCC, with external capacitor at AREF pin
    'INTERNAL : Internal 2.56 voltage reference with external capacitor ar AREF pin
    'Using the additional param on chip that do not have the internal reference will have no effect.
    habe die lösung gefunden für Bascom :
    $regfile = "m16def.dat"
    $crystal = 8000000
    $baud = 19200
    Dim Adhi As Byte
    Dim Adlow As Byte
    Dim Adcergebnis As Word
    Dim A As String * 10
    Config Porta = Input
    Disable Interrupts
    Adcsra.aden = 1
    Adcsra.adate = 1
    Adcsra.adie = 1
    Adcsra.adsc = 1
    Adcsra.adps0 = 1
    Adcsra.adps1 = 1
    Adcsra.adps2 = 1
    Admux.refs0 = 1
    Admux.mux0 = 1 ' adc1
    Enable Interrupts
    On Adc Onadc
    Do
    Input A
    Print A
    Waitms 10
    Loop
    Onadc:
       Adcsra.adsc = 1
       Adlow = Adcl
       Adhi = Adch
       Adcergebnis = Adhi * 256
       Adcergebnis = Adcergebnis + Adlow
       If Adcergebnis < 200 Then
         Print Adcergebnis
       End If
    Return
