Thema: Sensor wird nicht erkannt
    Rott am Inn
    Mein Programm
    $regfile = "M32def.dat"
    $crystal = 8000000
    $baud = 9600
    Declare Sub Read1820
    Declare Sub Crcit
    Declare Sub Temperature
    Dim Bd(9) As Byte
    Dim I As Byte , Tmp As Byte
    Dim Crc As Byte
    Dim T As Integer , T1 As Integer
    Dim V As Byte
    Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
    Config Lcd = 16 * 4
    Config 1wire = Portd.2
    Cursor Off Noblink
    Cls
    Locate 1 , 1 : Lcd "Brutkasten"
    Locate 2 , 1 : Lcd "T="
    Temperature
    Waitms 250
    End
    Sub Temperature ' actual measuring
    1wwrite &HCC : 1wwrite &H44 ' start measure
    Waitms 300 ' wait for end of conversion
    Read1820 ' read 9 bytes
    If Err = 1 Then ' if there is no sensor
    Locate 2 , 4 : Lcd "-- " ' we put "-- " on LCD
    Else
    If Crc = 0 Then ' sensor present, check CRC
    Locate 2 , 4 : Lcd T ' CRC OK, print T*10 on LCD
    Else
    Locate 2 , 4 : Lcd "** " ' CRC NOT OK, "** " on LCD
    End If
    End If
    End Sub
    Sub Read1820 ' reads sensor ans calculate
    ' T for 0.1 C
    1wreset ' reset the bus
    1wwrite &HCC ' read internal RAM
    1wwrite &HBE ' read 9 data bytest
    Bd(1) = 1wread(9) ' read bytes in array
    Crcit ' ckeck CRC
    If Crc = 0 Then ' if is OK, calculate for
    Tmp = Bd(1) And 1 ' 0.1C precision
    If Tmp = 1 Then Decr Bd(1)
    T = Makeint(bd(1) , Bd(2))
    T = T * 50 : T = T - 25 : T1 = Bd( Bild   - Bd(7) : T1 = T1 * 100
    T1 = T1 / Bd( Bild   : T = T + T1 : T = T / 10
    End If
    End Sub
    Sub Crcit ' calculate 8 bit CRC
    ' bigger but faster
    Crc = 0 ' needs a 256 elements table
    For I = 1 To 9
    Tmp = Crc Xor Bd(i)
    Crc = Lookup(tmp , Crc Bild
    Next
    End Sub
    Crc8:
    Data 0 , 94 , 188 , 226 , 97 , 63 , 221 , 131 , 194 , 156
    Data 126 , 32 , 163 , 253 , 31 , 65 , 157 , 195 , 33 , 127
    Data 252 , 162 , 64 , 30 , 95 , 1 , 227 , 189 , 62 , 96
    Data 130 , 220 , 35 , 125 , 159 , 193 , 66 , 28 , 254 , 160
    Data 225 , 191 , 93 , 3 , 128 , 222 , 60 , 98 , 190 , 224
    Data 2 , 92 , 223 , 129 , 99 , 61 , 124 , 34 , 192 , 158
    Data 29 , 67 , 161 , 255 , 70 , 24 , 250 , 164 , 39 , 121
    Data 155 , 197 , 132 , 218 , 56 , 102 , 229 , 187 , 89 , 7
    Data 219 , 133 , 103 , 57 , 186 , 228 , 6 , 88 , 25 , 71
    Data 165 , 251 , 120 , 38 , 196 , 154 , 101 , 59 , 217 , 135
    Data 4 , 90 , 184 , 230 , 167 , 249 , 27 , 69 , 198 , 152
    Data 122 , 36 , 248 , 166 , 68 , 26 , 153 , 199 , 37 , 123
    Data 58 , 100 , 134 , 216 , 91 , 5 , 231 , 185 , 140 , 210
    Data 48 , 110 , 237 , 179 , 81 , 15 , 78 , 16 , 242 , 172
    Data 47 , 113 , 147 , 205 , 17 , 79 , 173 , 243 , 112 , 46
    Data 204 , 146 , 211 , 141 , 111 , 49 , 178 , 236 , 14 , 80
    Data 175 , 241 , 19 , 77 , 206 , 144 , 114 , 44 , 109 , 51
    Data 209 , 143 , 12 , 82 , 176 , 238 , 50 , 108 , 142 , 208
    Data 83 , 13 , 239 , 177 , 240 , 174 , 76 , 18 , 145 , 207
    Data 45 , 115 , 202 , 148 , 118 , 40 , 171 , 245 , 23 , 73
    Data 8 , 86 , 180 , 234 , 105 , 55 , 213 , 139 , 87 , 9
    Data 235 , 181 , 54 , 104 , 138 , 212 , 149 , 203 , 41 , 119
    Data 244 , 170 , 72 , 22 , 233 , 183 , 85 , 11 , 136 , 214
    Data 52 , 106 , 43 , 117 , 151 , 201 , 74 , 20 , 246 , 168
    Data 116 , 42 , 200 , 150 , 21 , 75 , 169 , 247 , 182 , 232
    Data 10 , 84 , 215 , 137 , 107 , 53
    Der Temperatursensor wird nicht erkannt weil am Display--
    ausgegeben wird. Woran könnte das liegen, dass mein Sensor
    nicht erkannt wird?
    Danke für eure Hilfe[/code]
    Geh bitte, Franzl, kannst du die Code-Tags besser placieren ?
    ? Startest du die messung ohne reset vorher und ohne gesendeten CRC ? Tut er das so ? Ich müßt mir erst das DS vom DS1820 anschauen
    mfg robert
    Hast Du einen Pullup am Sensor ?
    LG
