Thema: Problem beim Compilieren
    Rott am Inn
    Wenn ich mein Programm Compiliere
    $regfile = "M32def.dat"
    $crystal = 8000000
    $baud = 9600
    declare sub Read1820
    declare sub CRCit
    declare sub Temperature
    dim bd(9) as byte
    dim i as byte , tmp as byte
    dim CRC as byte
    dim T as integer , T1 as integer
    dim v as byte
    Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
    Config Lcd = 16 * 4
    Config 1wire = Portd.2
    cursor off noblink
    cls
    Locate 1 , 1 : Lcd "Brutkasten"
    locate 2 , 1 : lcd "T="
    do
    Temperature
    waitms 250
    loop
    End
    sub Temperature ' actual measuring
    1wwrite &hcc : 1wwrite &h44 ' start measure
    waitms 300 ' wait for end of conversion
    Read1820 ' read 9 bytes
    if Err = 1 then ' if there is no sensor
    locate 2 , 4 : lcd "-- " ' we put "-- " on LCD
    else
    if CRC = 0 then ' sensor present, check CRC
    locate 2 , 4 : lcd T ' CRC OK, print T*10 on LCD
    else
    locate 2 , 4 : lcd "** " ' CRC NOT OK, "** " on LCD
    end if
    end if
    end sub
    sub Read1820 ' reads sensor ans calculate
    ' T for 0.1 C
    1wreset ' reset the bus
    1wwrite &hcc ' read internal RAM
    1wwrite &Hbe ' read 9 data bytest
    bd(1) = 1wread(9) ' read bytes in array
    CRCit ' ckeck CRC
    if CRC = 0 then ' if is OK, calculate for
    tmp = bd(1) and 1 ' 0.1C precision
    if tmp = 1 then decr bd(1)
    T = makeint(bd(1) , bd(2))
    T = T * 50 : T = T - 25 : T1 = bd( Bild   - bd(7) : T1 = T1 * 100
    T1 = T1 / bd( Bild   : T = T + T1 : T = T / 10
    end if
    end sub
    sub CRCit ' calculate 8 bit CRC
    ' bigger but faster
    CRC = 0 ' needs a 256 elements table
    for i = 1 to 9
    tmp = CRC xor bd(i)
    CRC = lookup(tmp , crc Bild
    next
    end sub
    crc8:
    data 0 , 94 , 188 , 226 , 97 , 63 , 221 , 131 , 194 , 156
    data 126 , 32 , 163 , 253 , 31 , 65 , 157 , 195 , 33 , 127
    data 252 , 162 , 64 , 30 , 95 , 1 , 227 , 189 , 62 , 96
    data 130 , 220 , 35 , 125 , 159 , 193 , 66 , 28 , 254 , 160
    data 225 , 191 , 93 , 3 , 128 , 222 , 60 , 98 , 190 , 224
    data 2 , 92 , 223 , 129 , 99 , 61 , 124 , 34 , 192 , 158
    data 29 , 67 , 161 , 255 , 70 , 24 , 250 , 164 , 39 , 121
    data 155 , 197 , 132 , 218 , 56 , 102 , 229 , 187 , 89 , 7
    data 219 , 133 , 103 , 57 , 186 , 228 , 6 , 88 , 25 , 71
    data 165 , 251 , 120 , 38 , 196 , 154 , 101 , 59 , 217 , 135
    Data 4 , 90 , 184 , 230 , 167 , 249 , 27 , 69 , 198 , 152
    Data 122 , 36 , 248 , 166 , 68 , 26 , 153 , 199 , 37 , 123
    data 58 , 100 , 134 , 216 , 91 , 5 , 231 , 185 , 140 , 210
    data 48 , 110 , 237 , 179 , 81 , 15 , 78 , 16 , 242 , 172
    data 47 , 113 , 147 , 205 , 17 , 79 , 173 , 243 , 112 , 46
    data 204 , 146 , 211 , 141 , 111 , 49 , 178 , 236 , 14 , 80
    data 175 , 241 , 19 , 77 , 206 , 144 , 114 , 44 , 109 , 51
    data 209 , 143 , 12 , 82 , 176 , 238 , 50 , 108 , 142 , 208
    data 83 , 13 , 239 , 177 , 240 , 174 , 76 , 18 , 145 , 207
    data 45 , 115 , 202 , 148 , 118 , 40 , 171 , 245 , 23 , 73
    data 8 , 86 , 180 , 234 , 105 , 55 , 213 , 139 , 87 , 9
    data 235 , 181 , 54 , 104 , 138 , 212 , 149 , 203 , 41 , 119
    data 244 , 170 , 72 , 22 , 233 , 183 , 85 , 11 , 136 , 214
    data 52 , 106 , 43 , 117 , 151 , 201 , 74 , 20 , 246 , 168
    data 116 , 42 , 200 , 150 , 21 , 75 , 169 , 247 , 182 , 232
    data 10 , 84 , 215 , 137 , 107 , 53
    Schreibt er immer
    Error:999 Line: 94 DEMO/BETA only supports 2048 bytes of code
    an was kann das liegen
    und wie kann ich es beheben?
    Danke [/code]
    Hard, Vorarlberg
    Ich glaube die Fehlermeldung ist klar. Du scheinst die Demo-Version von BASCOM-AVR zu verwenden und diese ist auf maximal 2KB erzeugten Code begrenzt. Dein Programm erzeugt 2144 Bytes Programmcode
    Du hast nun 2 Möglichkeiten:
    Entweder die Programmgröße auf dieses Limit reduzieren oder die Voll-Version zu kaufen. Ich würde Dir zu letzterem raten, da BASCOM-AVR ein sehr guten Preis/Leistungsverhältnis hat und für jeden, der ATMEL AVR Prozessoren mit der Programmsprache BASIC programmieren will es meines Erachtens der beste Compiler ist.
    Viele Grüße
    Josef
    DOS-File System für BASCOM-AVR auf http://members.aon.at/voegel
    in der neuesten Bascom Demoversion ist die Beschränkung auf 4 KB angehoben worden. (Steht so wenigstens in der History.txt)
    Vielleicht reichen dir ja erst einmal 4 KB..
    außerdem geht folgende Zeile zB. nicht:
    "T = T * 50 : T = T - 25 : T1 = bd(Cool - bd(7) : T1 = T1 * 100 "
    Bei Bascom mußt du leider immer alles schön einzeln und hintereinander machen.
    Also x=b*c / d
    geht nicht
    Hilfsvariable= b*c
    x= hilfsvariable / c
    das geht.
    Christopher
    Hard, Vorarlberg
    Diese Zeile wird vom Compiler akzeptiert, da die einzelnen Statements mit Doppelpunkt voneinander getrennt sind. Dieses Forum ersetzt allerdings manche Kombinationen mit ) wie bei bd(x) mit Smileys und beim rauskopieren und einfügen in die BASCOM-AVR wird dadurch der Code verändert, was wiederum Compiler-Fehler generiert.
    Viele Grüße
    Josef
    Füg mal
    $lib "mcsbyteint.LBX"
    im Listing mit ein. Also so...
    $crystal = 8000000
    $baud = 9600
    declare sub CRCit
    Es kann sein, das du damit unter die 2kb-Grenze kommst.
