Ergebnis 1 bis 10 von 16
Thema: fehlermeldung bei makefile
    ich habde das makefile mit mfile erstellt aber wenn ich es ausführen will bekommen ich immer die folgende fehlermeldung:
    was muss ich an den einstellungen ändern damit ich die hex datei erstellen kann?
    # Hey Emacs, this is a -*- makefile -*-
    # WinAVR Sample makefile written by Eric B. Weddington, Jörg Wunsch, et al.
    # Released to the Public Domain
    # Please read the make user manual!
    # Additional material for this makefile was submitted by:
    #  Tim Henigan
    #  Peter Fleury
    #  Reiner Patommel
    #  Sander Pool
    #  Frederik Rouleau
    #  Markus Pfaff
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
    # make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
    #                4.07 or greater).
    # make program = Download the hex file to the device, using avrdude.  Please
    #                customize the avrdude settings below first!
    # make filename.s = Just compile filename.c into the assembler code only
    # To rebuild project do "make clean" then "make all".
    # MCU name
    MCU = atmega32
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # Target file name (without extension).
    TARGET = versuch
    # List C source files here. (C dependencies are automatically generated.)
    SRC = $(TARGET).c io.h avr.h
    # List Assembler source files here.
    # Make them always end in a capital .S.  Files ending in a lowercase .s
    # will not be considered source files but generated files (assembler
    # output from the compiler), and will be deleted upon "make clean"!
    # Even though the DOS/Win* filesystem matches both .s and .S the same,
    # it will preserve the spelling of the filenames, and GCC itself does
    # care about how the name is spelled on its command-line.
    ASRC =
    # Optimization level, can be [0, 1, 2, 3, s].
    # 0 = turn off optimization. s = optimize for size.
    # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    # Debugging format.
    # Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
    # AVR (extended) COFF requires stabs, plus an avr-objcopy run.
    DEBUG = stabs
    # List any extra directories to look for include files here.
    #     Each directory must be seperated by a space.
    EXTRAINCDIRS =
    # Compiler flag to set the C Standard level.
    # c89   - "ANSI" C
    # gnu89 - c89 plus GCC extensions
    # c99   - ISO C99 standard (not yet fully implemented)
    # gnu99 - c99 plus GCC extensions
    CSTANDARD = -std=gnu99
    # Place -D or -U options here
    CDEFS =
    # Place -I options here
    CINCS =
    # Compiler flags.
    #  -g*:          generate debugging information
    #  -O*:          optimization level
    #  -f...:        tuning, see GCC manual and avr-libc documentation
    #  -Wall...:     warning level
    #  -Wa,...:      tell GCC to pass this to the assembler.
    #    -adhlns...: create assembler listing
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS) $(CINCS)
    CFLAGS += -O$(OPT)
    CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
    CFLAGS += -Wall -Wstrict-prototypes
    CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    # Assembler flags.
    #  -ahlms:    create listing
    #  -gstabs:   have the assembler create line number information; note that
    #             for use in COFF files, additional information about filenames
    #             and function names needs to be present in the assembler source
    #             files -- see avr-libc docs [FIXME: not yet described there]
    ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
    #Additional libraries.
    # Minimalistic printf version
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires MATH_LIB = -lm below)
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    PRINTF_LIB =
    # Minimalistic scanf version
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    SCANF_LIB =
    MATH_LIB = -lm
    # External memory options
    # 64 KB of external RAM, starting after internal RAM (ATmega128!),
    # used for variables (.data/.bss) and heap (malloc()).
    #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
    # only used for heap (malloc()).
    #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
    EXTMEMOPTS =
    # Linker flags.
    #  -Wl,...:     tell GCC to pass this to linker.
    #    -Map:      create map file
    #    --cref:    add cross reference to  map file
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    # Programming support using avrdude. Settings and variables.
    # Programming hardware: alf AVR910 avrisp Bascom bsd
    # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
    # Type: avrdude -c ?
    # to get a full listing.
    AVRDUDE_PROGRAMMER = stk500
    # com1 = serial port. Use lpt1 to connect to parallel port.
    AVRDUDE_PORT = com1    # Programmer connected to serial device
    AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
    #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
    # Uncomment the following if you want avrdude's erase cycle counter.
    # Note that this counter needs to be initialized first using -Yn,
    # see avrdude manual.
    #AVRDUDE_ERASE_COUNTER = -y
    # Uncomment the following if you do /not/ wish a verification to be
    # performed after programming the device.
    #AVRDUDE_NO_VERIFY = -V
    # Increase verbosity level.  Please use this when submitting bug
    # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
    # to submit bug reports.
    #AVRDUDE_VERBOSE = -v -v
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    # Define directories, if needed.
    DIRAVR = c:/winavr
    DIRAVRBIN = $(DIRAVR)/bin
    DIRAVRUTILS = $(DIRAVR)/utils/bin
    DIRINC = .
    DIRLIB = $(DIRAVR)/avr/lib
    # Define programs and commands.
    SHELL = sh
    CC = avr-gcc
    OBJCOPY = avr-objcopy
    OBJDUMP = avr-objdump
    SIZE = avr-size
    NM = avr-nm
    AVRDUDE = avrdude
    REMOVE = rm -f
    COPY = cp
    # Define Messages
    # English
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = --------  end  --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    # Define all object files.
    OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
    # Define all listing files.
    LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
    # Compiler flags to generate dependency files.
    GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    # Default target.
    all: begin gccversion sizebefore build sizeafter finished end
    build: elf hex eep lss sym
    elf: $(TARGET).elf
    hex: $(TARGET).hex
    eep: $(TARGET).eep
    lss: $(TARGET).lss
    sym: $(TARGET).sym
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    	@echo
    	@echo $(MSG_BEGIN)
    finished:
    	@echo $(MSG_ERRORS_NONE)
    end:
    	@echo $(MSG_END)
    	@echo
    # Display size of file.
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) -A $(TARGET).elf
    sizebefore:
    	@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
    sizeafter:
    	@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
    # Display compiler version information.
    gccversion :
    	@$(CC) --version
    # Program the device.
    program: $(TARGET).hex $(TARGET).eep
    	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
    COFFCONVERT=$(OBJCOPY) --debugging \
    --change-section-address .data-0x800000 \
    --change-section-address .bss-0x800000 \
    --change-section-address .noinit-0x800000 \
    --change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    	@echo
    	@echo $(MSG_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    	@echo
    	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    %.hex: %.elf
    	@echo
    	@echo $(MSG_FLASH) $@
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    %.eep: %.elf
    	@echo
    	@echo $(MSG_EEPROM) $@
    	-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
    # Create extended listing file from ELF output file.
    %.lss: %.elf
    	@echo
    	@echo $(MSG_EXTENDED_LISTING) $@
    	$(OBJDUMP) -h -S $< > $@
    # Create a symbol table from ELF output file.
    %.sym: %.elf
    	@echo
    	@echo $(MSG_SYMBOL_TABLE) $@
    	$(NM) -n $< > $@
    # Link: create ELF output file from object files.
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    	@echo
    	@echo $(MSG_LINKING) $@
    	$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    %.o : %.c
    	@echo
    	@echo $(MSG_COMPILING) $<
    	$(CC) -c $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C source files.
    %.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    %.o : %.S
    	@echo
    	@echo $(MSG_ASSEMBLING) $<
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list finished end
    clean_list :
    	@echo
    	@echo $(MSG_CLEANING)
    	$(REMOVE) $(TARGET).hex
    	$(REMOVE) $(TARGET).eep
    	$(REMOVE) $(TARGET).obj
    	$(REMOVE) $(TARGET).cof
    	$(REMOVE) $(TARGET).elf
    	$(REMOVE) $(TARGET).map
    	$(REMOVE) $(TARGET).a90
    	$(REMOVE) $(TARGET).sym
    	$(REMOVE) $(TARGET).lnk
    	$(REMOVE) $(TARGET).lss
    	$(REMOVE) $(OBJ)
    	$(REMOVE) $(LST)
    	$(REMOVE) $(SRC:.c=.s)
    	$(REMOVE) $(SRC:.c=.d)
    	$(REMOVE) .dep/*
    # Include the dependency files.
    -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
    # Listing of phony targets.
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex eep lss sym coff extcoff \
    clean clean_list program
    mfg clemens[/code]
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken fehlermeldung.jpg
    An der Saar
    Was sagt denn
    make --v
    Disclaimer: none. Sue me.
    Hi Clemens,
    ich kann auch nicht jetzt den Fehler sehen nur die Header io.h und avr.h würde ich im C Code einbinden!
    Gruß Michi
    Nochmalwas,
    kannste mal deinen C Code posten? Aber ich glaube eher dass es an deinen Programmeinstellungen liegt!
    Gruß Michi
    @sprinterSB was "make --v" bedeutet weiß ich leider nicht und ich habs im code nicht gefunden;
    die header hab ich jetzt geändert, aber es streikt noch immer. Bild
    kann es daran liegen dass ich XP verwende?
    thx für die antworten clemens
    edit: sorry hab dein post zu spät gesehen hir ist der code ( nicht von mir sondern aus dem i-net)
    #include <avr/io.h>
    char i=0; //Globale 8-Bit Variable
    void warten(int t) //ermöglicht Pausen
     int h;
     for (;t>0;t--)
      for (h=1600;h>0;h--) {}
     return;
    int main(void)
     char i=0; //Lokale 8-Bit Variable
     //Setzen der Ein + Ausgänge
     outp(0xFF,DDRB); //PortB: alles als Ausgäng
     outp(0xFF,DDRD); //PortD: alles als Ausgang
     //Ports digital ansteuern
     outp(0x0,PORTB); //Alle Ausgänge werden auf low gesetzt
     outp(0x0,PORTD); //Alle Ausgänge werden auf low gesetzt
    while (1)
       i++;
       outp(i,PORTB);
       warten (200);
    An der Saar
    An deinem C-Code liegts garantiert nicht.
    Da kannst du irgendwas hinschreiben, das meckert bestenfalls dein Compiler an, aber niemals nicht make oder XP.
    Gib auf einer Console mal 'make --v' ein und schau ob make überhaupt gestartet werden kann oder das make für ein anderes System gebuildet wurde (Windows32? mingw? ...)
    Oder ist das Problem, das einer der Aufrufe, die make machen will, von XP verweigert wird?
    Oder XP zu blöd ist, das makefile zu finden, weil Windoofs mit Groß/Kleinschreibung nicht richtig zurecht kommt?
    das makefile startet und das eingabe fenster erscheint, ruft massenweise befehle auf, 2sec geht das gut, dann kommt die fehlermeldung, wenn ich ignorieren auswähle ruft makefile weiter seine befehle auf, aber ich bekomme keine versuch.hex datei (nirgendwo ich habe nach "versuch" suchen lassen und nichts gefunden)
    mit welchem Programm arbeitest du? Mit winavr läufs bei mit XP!
    Gruß Michi
    habe auch das winavr mit programmers notepad2 und mit dem dazugehörigen mfile erstelle ich auch das makefile und zum überspielen ponny prog (aber zum überspielen bin ich noch nicht gekommen)
    gibt es keine möglichkeit das makefile zu umgehen oder eine andere anwendung um eine hex date zu erstellen?
    mfg clemens
    Hi user529,
    ich hab nen Fehler in deinem Makefile gefunden:
    statt
    das stehen weil du ja mit PonyProg programmierst:
    # Programming support using ponyprog. Settings and variables.
    #PONYPROG= ponyprog2000.exe
    PONYPROG= C:\Programme\ponyprog2000\ponyprog2000.exe
    	echo -e "SELECTDEVICE $(MCU)\nLOAD-PROG $(TARGET).hex\n#LOAD-DATA $(TARGET).eep\nWRITE-PROG" >isp.e2s
    	$(PONYPROG) isp.e2s
    Gruß Michi
