Ergebnis 11 bis 12 von 12
Thema: Stack-pointer positionirung
    An der Saar
    Versuchs mal mit dem Code unten.
    Falls das Programm nicht implizit davon ausgeht, daß die Datenfelder sine, triangle, etc auf 256-Byte-Grenze aligned sind, kannst du dir den durch das Alignment verschwendeten Platz sparen.
    Wirf dann einfach die ".align 8" Zeilen raus.
    .arch at90s2313
    ; start of code
    #include <avr/io.h>
    __SREG__ = 0x3f
    __SP_H__ = 0x3e
    __SP_L__ = 0x3d
    ; code
    .text
    .global	main
    .type	main, @function
    main:
          ldi      r16, lo8(RAMEND) ; RAMEND
          out      __SP_L__, r16      ; setup stack pointer
          ldi      r16, hi8(RAMEND) ; RAMEND
          out      __SP_H__, r16      ; setup stack pointer
          ldi      r16,0x05      ; set UART speed to 115.2 kbps
          out      UBRR,r16
          ldi      r16,0x98      ; enable RXint and enable tx/rx
          out      UCR,r16
          sei                  ; global enable interrupts
          ser      r16            ;
          out      DDRB,r16      ; set all PORTB bits as output
          ; set sinewave output as default
          ldi      r31,hi8(sine)   ; setup Z pointer hi
          ldi      r30,lo8(sine)   ; setup Z pointer lo
          ; clear accumulator
          ldi    r29,0x00      ; clear accumulator
          ldi    r28,0x00      ; clear accumulator
          ; setup adder registers
          ldi    r24,0x55      ; setup adder value
          ldi    r25,0x35      ; to 1 kHz
          ldi    r26,0x00      ;
    ; main loop
    ;   r28,r29,r30 is the phase accumulator
    ;     r24,r25,r26 is the adder value determining frequency
    ;    add value to accumulator
    ;   load byte from current table in ROM
    ;   output byte to port
    ;   repeat
    LOOP1:
          add      r28,r24         ; 1
          adc      r29,r25         ; 1
          adc      r30,r26         ; 1
          lpm                  ; 3
          out      PORTB,r0      ; 1
          rjmp   LOOP1         ; 2 => 9 cycles
    ; communication functionality
    ; get char in r16
    get_char:
          in       r16,USR         ; wait for a byte to be ready
          sbrs   r16,7         ; ready ?
          rjmp   get_char      ; no, wait some more
          in      r16,UDR         ; get the byte
          ret                  ; and return
    ; send char in r16
    send_char:
          push   r16            ; save r16
    send_c2:
          in       r16,USR         ; wait for the transmitter to be ready
          sbrs   r16,5         ; ready ?
          rjmp   send_c2         ; no, wait some more
          pop      r16            ; restore r16
          out      UDR,r16         ; send char
          ret                  ; ans return
    ; send the current frequency to the PC
    ; as a 5 byte sequence :
    ; 'F' folowed by a 32 bit phase accumulator value
    send_data:
          push   r16            ; save r16
          ldi      r16,'F'         ; flag
          rcall   send_char
          clr      r16            ; zero byte for 32-bit compatibility
          rcall   send_char      ; MSB
          mov      r16,r26
          rcall   send_char      ; high add
          mov      r16,r25
          rcall   send_char      ; mid add
          mov      r16,r24
          rcall   send_char      ; low add
          ldi      r16,0x0a
          rcall   send_char      ; terminator
          pop      r16
          ret
    ; add 1 to the phase accumulator
    up_one:
          adiw   r24,1
          clr      r23
          adc      r26,r23
          ret
    ; add 10 to the phase accumulator
    up_ten:
          adiw   r24,10
          clr      r23
          adc      r26,r23
          ret
    ; add 100 to the phase accumulator
    up_hundred:
          ldi      r23,0x64
          add      r24,r23
          clr      r23
          adc      r25,r23
          adc      r26,r23
          ret
    ; subtract 1 from the phase accumulator
    down_one:
          sbiw   r24,1
          clr      r23
          sbc      r26,r23
          ret
    ; subtract 10 from the phase accumulator
    down_ten:
          sbiw   r24,10
          clr      r23
          sbc      r26,r23
          ret
    ; subtract 100 from the phase accumulator
    down_hundred:
          clr      r23
          subi   r24,0x64
          sbc      r25,r23
          sbc      r26,r23
          ret
    ; read in 4 characters from the serial link
    read_4:
          rcall   get_char      ; read and ignore bits 32..24
          rcall   get_char      ; read bits 23..16
          mov      r26,r16
          rcall   get_char      ; read bits 15..8
          mov      r25,r16
          rcall   get_char      ; read bits 7..0
          mov      r24,r16
          ret
    ; Interrupt routine for incoming bytes on the RS232 link
    .global	SIG_UART_RECV
    SIG_UART_RECV:
          push   r16
          in       r16,UDR
          cpi      r16,'+'            ; up one
          brne   tx_2
          rcall   up_one
          rjmp   tx_exit
    tx_2:
          cpi      r16,'u'            ; up ten
          brne   tx_3
          rcall   up_ten
          rjmp   tx_exit
    tx_3:
          cpi      r16,'U'            ; up hundred
          brne   tx_4
          rcall   up_hundred
          rjmp   tx_exit
    tx_4:
          cpi      r16,'-'            ; down one
          brne   tx_5
          rcall   down_one
          rjmp   tx_exit
    tx_5:
          cpi      r16,'d'            ; down ten
          brne   tx_6
          rcall   down_ten
          rjmp   tx_exit
    tx_6:
          cpi      r16,'D'            ; down hundred
          brne   tx_7
          rcall   down_hundred
          rjmp   tx_exit
    tx_7:
          cpi      r16,'s'            ; frequency setting
          brne   tx_8
          rcall   read_4
          rjmp   tx_exit
    tx_8:
          cpi      r16,'?'            ; just force a reply
          brne   tx_9
          rjmp   tx_exit
    tx_9:
          cpi      r16,'1'            ; request sinewave output
          brne   tx_10
          rjmp   tx_exit
    tx_10:
          cpi      r16,'2'            ; request sawtooth output
          brne   tx_11
          ldi      r31,hi8(sawtooth)   ; setup Z pointer hi
          ldi      r30,lo8(sawtooth)   ; setup Z pointer lo
          rjmp   tx_exit
    tx_11:
          cpi      r16,'3'            ; request triangle output
          brne   tx_12
          ldi      r31,hi8(triangle)   ; setup Z pointer hi
          ldi      r30,lo8(triangle)   ; setup Z pointer lo
          rjmp   tx_exit
    tx_12:
          cpi      r16,'4'            ; request squarewave output
          brne   tx_13
          ldi      r31,hi8(square)      ; setup Z pointer hi
          ldi      r30,lo8(square)      ; setup Z pointer lo
          rjmp   tx_exit
    ; unknown command, just ignore it
    tx_13:
    ; always reply with the current frequency
    tx_exit:
          rcall   send_data
          pop      r16
          reti
    ; data tables
    .text
    .align 8
    sine:      ; 256 step sinewave table
       .byte   0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae
       .byte   0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8
       .byte   0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5
       .byte   0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff
       .byte   0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7
       .byte   0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc
       .byte   0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3
       .byte   0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83
       .byte   0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51
       .byte   0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27
       .byte   0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a
       .byte   0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00
       .byte   0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08
       .byte   0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23
       .byte   0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c
       .byte   0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c
    .align 8
    sawtooth:   ; 256 step sawtoothwave table
       .byte   0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f
       .byte   0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f
       .byte   0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f
       .byte   0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f
       .byte   0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f
       .byte   0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f
       .byte   0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f
       .byte   0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f
       .byte   0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f
       .byte   0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f
       .byte   0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf
       .byte   0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf
       .byte   0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf
       .byte   0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf
       .byte   0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef
       .byte   0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff
    .align 8
    triangle:   ; 256 step trianglewave table
       .byte   0x00,0x02,0x04,0x06,0x08,0x0a,0x0c,0x0e,0x10,0x12,0x14,0x16,0x18,0x1a,0x1c,0x1e
       .byte   0x20,0x22,0x24,0x26,0x28,0x2a,0x2c,0x2e,0x30,0x32,0x34,0x36,0x38,0x3a,0x3c,0x3e
       .byte   0x40,0x42,0x44,0x46,0x48,0x4a,0x4c,0x4e,0x50,0x52,0x54,0x56,0x58,0x5a,0x5c,0x5e
       .byte   0x60,0x62,0x64,0x66,0x68,0x6a,0x6c,0x6e,0x70,0x72,0x74,0x76,0x78,0x7a,0x7c,0x7e
       .byte   0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e,0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e
       .byte   0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xae,0xb0,0xb2,0xb4,0xb6,0xb8,0xba,0xbc,0xbe
       .byte   0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcc,0xce,0xd0,0xd2,0xd4,0xd6,0xd8,0xda,0xdc,0xde
       .byte   0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xee,0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,0xfe
       .byte   0xff,0xfd,0xfb,0xf9,0xf7,0xf5,0xf3,0xf1,0xef,0xef,0xeb,0xe9,0xe7,0xe5,0xe3,0xe1
       .byte   0xdf,0xdd,0xdb,0xd9,0xd7,0xd5,0xd3,0xd1,0xcf,0xcf,0xcb,0xc9,0xc7,0xc5,0xc3,0xc1
       .byte   0xbf,0xbd,0xbb,0xb9,0xb7,0xb5,0xb3,0xb1,0xaf,0xaf,0xab,0xa9,0xa7,0xa5,0xa3,0xa1
       .byte   0x9f,0x9d,0x9b,0x99,0x97,0x95,0x93,0x91,0x8f,0x8f,0x8b,0x89,0x87,0x85,0x83,0x81
       .byte   0x7f,0x7d,0x7b,0x79,0x77,0x75,0x73,0x71,0x6f,0x6f,0x6b,0x69,0x67,0x65,0x63,0x61
       .byte   0x5f,0x5d,0x5b,0x59,0x57,0x55,0x53,0x51,0x4f,0x4f,0x4b,0x49,0x47,0x45,0x43,0x41
       .byte   0x3f,0x3d,0x3b,0x39,0x37,0x35,0x33,0x31,0x2f,0x2f,0x2b,0x29,0x27,0x25,0x23,0x21
       .byte   0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x11,0x0f,0x0f,0x0b,0x09,0x07,0x05,0x03,0x01
    .align 8
    square:      ; 256 step squarewave table
       .byte   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
       .byte   0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
    ; end of file
    Disclaimer: none. Sue me.
    kompilieren geht schon mal zum testen habe ich erst nachmittag zeit
