Ergebnis 1 bis 2 von 2
Thema: DS1621 [NEW v1,2] for C-Control I v1.1 & v2.0
    Earth
    Liest die Temperatur mit 9 Bits vom DS1621 und zeigt die Temperatur als °C und °F an.
    Reads the 9 bit temperature from the DS1621 and displays the temperature as °C and °F.
    Grüße/ Greetings,
    H.J. Windt
    Earth
    Hello,
    Someone in another forum warned me about a small error in the DS1621 examples.
    The problem is not with the temp_c and temp_f variables but with the way they are displayed.
    -0,5°C would be displayed as 0,5°C and -0,4°F would be displayed as 0,4°F.
    The problem was with breaking up the numbers to display the “,”.
    I have solved the problem and version 1.2 for C-Control I v1.1 & v2.0 are available for download.
    DS1621 Example for C-Control I v1.1
    https://www.roboternetz.de/phpBB2/dl...le&file_id=301
    DS1621 Example for C-Control I v2.0
    https://www.roboternetz.de/phpBB2/dl...le&file_id=302
    Sorry if this gave anybody any problems.
    Greetings,
    H.J. Windt
