Mithilfe von Dirks Servo Base Bibliothek und dem TV_Remote Bspl habe ich folgendes Programm "geschrieben" :
Code:// written David Smutny
// RP6BaseServoLib was written by Dirk
#include "RP6BaseServoLib.h"
#include "RP6RobotBaseLib.h"
#define RC_YOUR_OWN
#ifdef RC_YOUR_OWN
#define RC5_KEY_LEFT 20
#define RC5_KEY_RIGHT 22
#define RC5_KEY_FORWARDS 18
#define RC5_KEY_BACKWARDS 24
#define RC5_KEY_STOP 32
#define RC5_KEY_CURVE_LEFT 17
#define RC5_KEY_CURVE_RIGHT 19
#define RC5_KEY_CURVE_BACK_LEFT 23
#define RC5_KEY_CURVE_BACK_RIGHT 25
#define RC5_KEY_LEFT_MOTOR_FWD 26
#define RC5_KEY_LEFT_MOTOR_BWD 41
#define RC5_KEY_RIGHT_MOTOR_FWD 42
#define RC5_KEY_RIGHT_MOTOR_BWD 49
#define RC5_KEY_SERVO_L 37
#define RC5_KEY_SERVO_R 36
#endif
#define MAX_SPEED_MOVE 200
#define MAX_SPEED_TURN 100
#define MAX_SPEED_CURVE 120
#define MAX_SPEED_CURVE2 40
#define ACCELERATE_CURVE 10
#define ACCELERATE_CURVE2 4
#define DECELERATE_CURVE 4
#define DECELERATE_CURVE2 2
#define MAX_SPEED_1_MOTOR 120
#define ACCELERATE_VALUE 8
#define DECELERATE_VALUE 4
uint8_t max_speed_left;
uint8_t max_speed_right;
uint8_t acl_left;
uint8_t acl_right;
uint8_t decl_left;
uint8_t decl_right;
uint16_t pos = 0;
uint8_t servorcan = 1; //rechter Servo
uint8_t servolcan = 1; //linker Ser
void setDefaultSpeedParameters(void)
max_speed_left = MAX_SPEED_MOVE;
max_speed_right = max_speed_left;
acl_left = ACCELERATE_VALUE;
acl_right = ACCELERATE_VALUE;
decl_left = DECELERATE_VALUE;
decl_right = DECELERATE_VALUE;
uint16_t tmp = (getDesSpeedLeft() + getDesSpeedRight())/2;
moveAtSpeed(tmp , tmp);
void receiveRC5Data(RC5data_t rc5data)
writeString_P("Toggle Bit:");
writeChar(rc5data.toggle_bit + '0');
writeString_P(" | Device Address:");
writeInteger(rc5data.device, DEC);
writeString_P(" | Key Code:");
writeInteger(rc5data.key_code, DEC);
writeChar('\n');
#ifndef DO_NOT_MOVE
uint8_t movement_command = false;
switch(rc5data.key_code)
case RC5_KEY_LEFT:
writeString_P("LEFT\n");
setDefaultSpeedParameters();
max_speed_left = MAX_SPEED_TURN;
changeDirection(LEFT);
setLEDs(0b100000);
movement_command = true;
break;
case RC5_KEY_RIGHT:
writeString_P("RIGHT\n");
changeDirection(RIGHT);
setLEDs(0b000100);
break;
case RC5_KEY_FORWARDS:
writeString_P("FORWARDS\n");
changeDirection(FWD);
setLEDs(0b100100);
break;
case RC5_KEY_BACKWARDS:
writeString_P("BACKWARDS\n");
changeDirection(BWD);
setLEDs(0b001001);
break;
case RC5_KEY_STOP:
writeString_P("STOP\n");
max_speed_left = 0;
moveAtSpeed(0,0);
setLEDs(0b011011);
break;
case RC5_KEY_CURVE_LEFT:
writeString_P("CURVE LEFT FWD\n");
max_speed_left = MAX_SPEED_CURVE2;
max_speed_right = MAX_SPEED_CURVE;
acl_left = ACCELERATE_CURVE2;
acl_right = ACCELERATE_CURVE;
decl_left = DECELERATE_CURVE2;
decl_right = DECELERATE_CURVE;
setLEDs(0b110100);
break;
case RC5_KEY_CURVE_RIGHT:
writeString_P("CURVE RIGHT FWD\n");
max_speed_left = MAX_SPEED_CURVE;
max_speed_right = MAX_SPEED_CURVE2;
acl_left = ACCELERATE_CURVE;
acl_right = ACCELERATE_CURVE2;
decl_left = DECELERATE_CURVE;
decl_right = DECELERATE_CURVE2;
setLEDs(0b100110);
break;
case RC5_KEY_CURVE_BACK_LEFT:
writeString_P("CURVE LEFT BWD\n");
setLEDs(0b011001);
break;
case RC5_KEY_CURVE_BACK_RIGHT:
writeString_P("CURVE RIGHT BWD\n");
setLEDs(0b001011);
break;
case RC5_KEY_LEFT_MOTOR_FWD:
writeString_P("MOTOR LEFT FWD\n");
max_speed_left = 0;
max_speed_right = MAX_SPEED_1_MOTOR;
acl_left = 4;
acl_right = 4;
decl_left = 4;
decl_right = 4;
setLEDs(0b110000);
break;
case RC5_KEY_LEFT_MOTOR_BWD:
writeString_P("MOTOR LEFT BWD\n");
max_speed_left = 0;
acl_left = 4;
acl_right = 4;
decl_left = 4;
decl_right = 4;
setLEDs(0b101000);
break;
case RC5_KEY_RIGHT_MOTOR_FWD:
writeString_P("MOTOR RIGHT FWD\n");
max_speed_left = MAX_SPEED_1_MOTOR;
max_speed_right = 0;
acl_left = 4;
acl_right = 4;
decl_left = 4;
decl_right = 4;
setLEDs(0b000110);
break;
case RC5_KEY_RIGHT_MOTOR_BWD:
writeString_P("MOTOR RIGHT BWD\n");
acl_left = 4;
acl_right = 4;
decl_left = 4;
decl_right = 4;
setLEDs(0b000101);
break;
case RC5_KEY_SERVO_L:
writeString_P("Servo nach links\n");
pos -= 10;
break;
case RC5_KEY_SERVO_R:
writeString_P("Servo nach rechts\n");
pos += 10;
break;
if(movement_command)
if(getDesSpeedLeft() < max_speed_left)
moveAtSpeed(getDesSpeedLeft()+acl_left, getDesSpeedRight());
if(getDesSpeedLeft() < 10)
moveAtSpeed(10, getDesSpeedRight());
if(getDesSpeedRight() < max_speed_right)
moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()+acl_right);
if(getDesSpeedRight() < 10)
moveAtSpeed(getDesSpeedLeft(), 10);
setStopwatch4(0);
startStopwatch4();
#endif
void deccelerate(void)
if(getStopwatch4() > 250)
if(getDesSpeedLeft() <= 10)
moveAtSpeed(0, getDesSpeedRight());
else
moveAtSpeed(getDesSpeedLeft()-decl_left, getDesSpeedRight());
if(getDesSpeedRight() <= 10)
moveAtSpeed(getDesSpeedLeft(), 0);
else
moveAtSpeed(getDesSpeedLeft(), getDesSpeedRight()-decl_right);
if (getDesSpeedRight() == 0 && getDesSpeedLeft() == 0)
stopStopwatch1();
max_speed_left = getDesSpeedLeft();
max_speed_right = getDesSpeedRight();
setLEDs(0b000000);
setStopwatch4(0);
if(getDesSpeedLeft() > max_speed_left)
else
if(getDesSpeedRight() > max_speed_right)
else
int main(void)
initRobotBase();
setLEDs(0b111111);
writeChar('\n');
writeString_P("RP6 controlled by RC5 TV Remote\n");
writeString_P("___________________________\n");
mSleep(500);
setLEDs(0b000000);
powerON();
IRCOMM_setRC5DataReadyHandler(receiveRC5Data);
writeString_P("\n * Turn Left: "); writeInteger(RC5_KEY_LEFT, DEC);
writeString_P("\n * Turn Right: "); writeInteger(RC5_KEY_RIGHT, DEC);
writeString_P("\n * Move Forwards: "); writeInteger(RC5_KEY_FORWARDS, DEC);
writeString_P("\n * Move Backwards: "); writeInteger(RC5_KEY_BACKWARDS, DEC);
writeString_P("\n * Stop: "); writeInteger(RC5_KEY_STOP, DEC);
writeString_P("\n * Move curve left forwards: "); writeInteger(RC5_KEY_CURVE_LEFT, DEC);
writeString_P("\n * Move curve right forwards: "); writeInteger(RC5_KEY_CURVE_RIGHT, DEC);
writeString_P("\n * Move curve left backwards: "); writeInteger(RC5_KEY_CURVE_BACK_LEFT, DEC);
writeString_P("\n * Move curve right backwards: "); writeInteger(RC5_KEY_CURVE_BACK_RIGHT, DEC);
writeString_P("\n * Motor left forwards: "); writeInteger(RC5_KEY_LEFT_MOTOR_FWD, DEC);
writeString_P("\n * Motor left backwards: "); writeInteger(RC5_KEY_LEFT_MOTOR_BWD, DEC);
writeString_P("\n * Motor right forwards: "); writeInteger(RC5_KEY_RIGHT_MOTOR_FWD, DEC);
writeString_P("\n * Motor right backwards: "); writeInteger(RC5_KEY_RIGHT_MOTOR_BWD, DEC);
writeString_P("\n * Servo nach rechts: "); writeInteger(RC5_KEY_SERVO_R, DEC);
writeString_P("\n * Servo nach links: "); writeInteger(RC5_KEY_SERVO_L, DEC);
writeString_P("\n-----------------------\n");
startStopwatch2();
initSERVO(SERVO1);
while(true)
servo1_position = pos;
deccelerate();
task_RP6System();
return 0;
Wenn ich nun die entsprechende Taste drücke bewegt sich der servo aber nicht... :-s
Kann mir jemand helfen?
danke schonmal
gruß
David
