jetzt kommt der fehler
-------- begin --------
avr-gcc --version
avr-gcc (GCC) 3.3.1
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
test.c: In function `main':
test.c:12: error: parse error before '{' token
test.c:6: warning: unused variable `lineData'
test.c: At top level:
test.c:19: error: parse error before '}' token
make: *** [test.o] Error 1
> Process Exit Code: 2
Code:#include "asuro.h"
#define SPEED 0x8F
int speedLeft,speedRight;
unsigned int lineData[2];
int ADOffset;
void LineLeft (void)
speedLeft += 1;
if (speedLeft > 0xFE) speedLeft = 0xFF;
void LineRight (void)
speedRight += 1;
if (speedRight > 0xFE) speedRight = 0xFF;
int main(void)
int i;
unsigned char j;
Init();
FrontLED(ON);
(;;while(1) (j = 0; j < 0xFF; j++) {
LineData(lineData);}
LineData(lineData);
ADOffset = lineData[0] - lineData[1];
speedLeft = speedRight = SPEED;
(;;while(1) {
LineData(lineData);
i = (lineData[0] - lineData[1]) - ADOffset;
if ( i > 4) {
StatusLED(GREEN);
LineLeft();
else if ( i < -4) {
StatusLED(RED);
LineRight();
else {
StatusLED(OFF);
MotorSpeed(speedLeft,speedRight);
return(0);
