Das mit der globalen Variable gefällt mir zwar immer noch nicht aber ich bin aktuell zu doof um es anders zu regeln.
So funktioniert es auf jeden Fall!
#include <alsa/asoundlib.h>
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
using namespace std;
typedef struct _FILE_head
unsigned char ID[4];
unsigned int Length;
unsigned char Type[4];
} FILE_head;
typedef struct _FORMAT
short wFormatTag;
unsigned short wChannels;
unsigned int dwSamplesPerSec;
unsigned int dwAvgBytesPerSec;
unsigned short wBlockAlign;
unsigned short wBitsPerSample;
} FORMAT;
typedef struct _CHUNK_head
} CHUNK_head;
snd_pcm_t *soundKarte;
bool Init(const char *name, unsigned int channels, unsigned int actualRate, unsigned short WaveBits)
int err;
snd_pcm_format_t bits;
unsigned int resample = 1;
switch(WaveBits)
case 8:
bits = SND_PCM_FORMAT_U8;
break;
case 16:
bits = SND_PCM_FORMAT_S16;
break;
case 24:
bits = SND_PCM_FORMAT_S24;
break;
case 32:
bits = SND_PCM_FORMAT_S32;
break;
snd_pcm_hw_params_t *hw_params;
if(name == NULL)
err = snd_pcm_open(&soundKarte, "plughw:1,0", SND_PCM_STREAM_PLAYBACK, 0);
else
err = snd_pcm_open (&soundKarte, name, SND_PCM_STREAM_PLAYBACK, 0);
if(err < 0)
cout << "Init: Kann die Soundkarte nicht öffnen! " << name << " (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params_malloc(&hw_params)) < 0)
cout << "Init: Parameter können nicht initialisiert werden (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params_any(soundKarte, hw_params)) < 0)
cout << "Init: Parameter können nicht ermittelt werden (" << snd_strerror (err) << ")" << endl;
return false;
err = snd_pcm_hw_params_set_rate_resample(soundKarte, hw_params, resample);
if(err < 0)
cout << "Init: Resampling kann nicht eingeschaltet werden " << snd_strerror(err) << endl;
return err;
if((err = snd_pcm_hw_params_set_access(soundKarte, hw_params, SND_PCM_ACCESS_RW_INTERLEAVED)) < 0)
cout << "Init: Zugriffstyp kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params_set_format(soundKarte, hw_params, bits)) < 0)
cout << "Init: Sample-Format kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params_set_channels(soundKarte, hw_params, channels)) < 0)
cout << "Init: Anzahl der Kanäle kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params_set_rate_near(soundKarte, hw_params, &actualRate, 0)) < 0)
cout << "Init: Sample-Rate kann nicht auf " << actualRate << " gesetzt werden (" << snd_strerror (err) << ")" << endl;
return false;
if((err = snd_pcm_hw_params (soundKarte, hw_params)) < 0)
cout << "Init: Üarameters können nicht gesetzt werden(" << snd_strerror (err) << ")" << endl;
return false;
// snd_pcm_hw_params_get_buffer_size(hw_params, &bufferSize);
snd_pcm_hw_params_free(hw_params);
if((err = snd_pcm_prepare(soundKarte)) < 0)
cout << "Init: Audio kann nicht zur Nutzung vorbereitet werden (" << snd_strerror (err) << ")" << endl;
return false;
return true;
bool UnInit()
snd_pcm_close(soundKarte);
return true;
int main()
FORMAT format;
FILE_head head;
CHUNK_head chead;
char *wave;
register snd_pcm_uframes_t count, frames;
int datei;
unsigned int WaveSize;
datei = open("/home/pi/Music/cantalow.wav", 00);
read(datei, &head, sizeof(FILE_head));
read(datei, &chead, sizeof(CHUNK_head));
read(datei, &format, sizeof(FORMAT));
wave = (char *) malloc(head.Length);
read(datei, wave, head.Length);
WaveSize = head.Length * 8 / ((unsigned int)format.wBitsPerSample * (unsigned int)format.wChannels);
close(datei);
Init("plughw:1,0", format.wChannels, format.dwSamplesPerSec, format.wBitsPerSample);
count = 0;
do
frames = snd_pcm_writei(soundKarte, wave + count, WaveSize - count);
if (frames < 0) frames = snd_pcm_recover(soundKarte, frames, 0);
if (frames < 0)
printf("Kann wav nicht abspielen: %s\n", snd_strerror(frames));
break;
count += frames;
} while (count < WaveSize);
if (count == WaveSize) snd_pcm_drain(soundKarte);
free(wave);
UnInit();
return 0;
in welchem Ober-Verzeichnis liegt deine alsa/asoundlib.h ?
und wie lautet deine Compile/Build Parameter Liste?
und wo steht, was "soundKarte" ist ? Bzw. wie man das auf die eingebaute oder andere externe "Karten" umstellt?
bedeutet, die zweite verfügbare Soundkarte. Demnach darf die modprobe nicht dahin geändert werden, dass USB-Sound die erste ist. Falls das geändert wurde, dann
Dazu notwendig ist (falls noch nicht vorhanden)
sudo apt-get install libasound2-dev
sowie braucht es beim Linken noch
für g++.
- - - Aktualisiert - - -
Das übergibst du bei
Wie Peter schon sagte, 1 ist die zweite verfügbare Soundkarte. Da Raspi eine drin hat ist diese 0. Welche Nummer die entsprechende Karte hat kannst du zum Beispiel mit
heraus finden.
ok, ich hab heute abend wieder einen Pi (2).
Wie ist jetzt der genaue komplette g++ Build-Befehl (ich verwende ja Geany, das hat aber die gleichen wie der normale make Befehl) ?
Und in welchem Ober-Verzeichnis liegt deine alsa/asoundlib.h ?
Ich verwende im Moment auch Geany. Nur mein eigentlicher Bot will cmake.
Kompilieren:
g++ -Wall -std=c++0x -pthread -lasound -c "%f"
Erstellen:
g++ -Wall -std=c++0x -pthread -lasound -o "%e" "%f"
was ist c++0x und warum?
ich habe
-std=c++11
c++0x stand schon in der Zeile. Da habe ich hier nichts dran geändert. c++11 geht natürlich auch!
Wenn du libasound2-dev installiert hast liegt es im Standardverzeichnis. Also ich musste da nichts ändern oder irgendwo rein kopieren.
ich hatte mal was installiert aber woanders hin.
Daher muss ich wissen, wie dein Verzeichnis genau heißt und wo es liegt.
ps, hast du auch das installiert?
git clone https://github.com/tinyalsa/tinyalsa.git
cd tinyalsa
make
hmmmm
schriebst du nicht oben, du würdest tinyalsa benutzen - oder habe ich da was falsch gelesen?
sieht nämlich so aus, al ob du gar nicht tinyalsa benutzt, sondern das originale alsa .... kann das sein?
edit -
alles klar, es hat mit der tinyalsa-Lib nichts zu tun!
Dann ist es auch klar, dass das mit den lib-Pfaden nicht passte, das hat sich also erledigt.
Gute Nachricht:
Beispielprogramm lässt sich compilieren und läuft!
:cool:
Recht hast du. Tinyalsa mag ja gut sein, aber ohne Dokumentation ist das einfach Müll. Klar kann man es aus dem Quelltext heraus suchen, aber das ist mühsam. Also habe ich es mal mit Alsa selbst versucht und siehe da, funktioniert. Zudem finden sich für Alsa selbst hier und da Tutorials bzw. Einträge in Foren. Jedes Problem das ich hatte hatte auch schon irgend wer vor mir und von daher bekam ich in der Regel auch die Antworten dazu.
Also weg mit Tinyalsa ;). Habe ich im ersten Post hier im Threat auch schon geändert.
