Hi
Habs nun nachn bischen probieren und nochmal komplett neu schreiben hinbekommen.
Code:define LIGHT as port[16]
define BPORT1 as byteport[1]
import "...\LIB\SHOW_BINARY.BAS"
import "...\LIB\PULLUP1_ENABLE.BAS"
define ADC8 ad[8]
define SDA as port[9]
define SCL as port[10]
define EXTPORT as byteport[4]
define STATION_IO as byte[3]
define REL1 as bit [21]
define REL2 as bit [22]
define REL3 as bit [23]
define REL4 as bit [24]
PULLUP1_ENABLE()
LIGHT=off
LCD.INIT
SDA=on
SCL=on
STATION_IO=OFF
#HAUPTSCHLEIFE
EXTPORT=STATION_IO
LCD.POS 1,1
LCD.PRINT "BINARY: "
SHOW_BINARY(BPORT1)
'--- D1 - D4 ---
if (BPORT1 = 11111110b) then
Loop Until BPORT1 <> 11111110b
if ( REL1 = OFF) then
REL1 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
if ( REL1 = ON) then
REL1 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 11111101b) then
Loop Until BPORT1 <> 11111101b
if ( REL2 = OFF) then
REL2 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
if ( REL2 = ON) then
REL2 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 11111011b) then
Loop Until BPORT1 <> 11111011b
if ( REL3 = OFF) then
REL3 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
if ( REL3 = ON) then
REL3 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 11110111b) then
Loop Until BPORT1 <> 11110111b
if ( REL4 = OFF) then
REL4 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
if ( REL4 = ON) then
REL4 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
end if
'--- D5 - D8 ---
if (BPORT1 = 11101111b) then
Loop Until BPORT1 <> 11101111b
REL1 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
REL1 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 11011111b) then
Loop Until BPORT1 <> 11011111b
REL2 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
REL2 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 10111111b) then
Loop Until BPORT1 <> 10111111b
REL3 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
REL3 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
goto HAUPTSCHLEIFE
end if
if (BPORT1 = 01111111b) then
Loop Until BPORT1 <> 01111111b
REL4 = ON
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
REL4 = OFF
EXTPORT=STATION_IO
goto HAUPTSCHLEIFE
end if
end if
goto HAUPTSCHLEIFE
