Zitat:
			Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/cysign/emc2/configs/stepper'
Machine configuration file is 'stepper_mm.ini'
INIFILE=/home/cysign/emc2/configs/stepper/stepper_mm.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=2858
Killing task milltask, PID=2902
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
/usr/bin/emc: line 654:  2903 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2858
  PID TTY      STAT   TIME COMMAND
2902
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 5349.040708] I-pipe: Domain RTAI registered.
[ 5349.040746] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 5349.040754] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 5349.040776] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5349.040783] PIPELINE layers:
[ 5349.040792] e0ee3e20 9ac15d93 RTAI 200
[ 5349.040799] c085cb20 0 Linux 100
[ 5349.203065] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5349.208802] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 5349.208821] RTAI[sched]: hard timer type/freq = APIC/6215281(Hz); default timing: periodic; linear timed lists.
[ 5349.208831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 994510000 hz.
[ 5349.208838] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5349.209489] RTAI[usi]: enabled.
[ 5349.812203] RTAI[math]: loaded.
[ 5350.405575] config string '0x0378'
[ 5357.252447] __ratelimit: 9 callbacks suppressed
[ 5357.252471] axis[2903]: segfault at 0 ip (null) sp bfef567c error 4 in libssl.so.0.9.8[110000+42000]
[ 5364.585029] RTAI[math]: unloaded.
[ 5364.916263] SCHED releases registered named ALIEN RTGLBH
[ 5364.933228] RTAI[malloc]: unloaded.
[ 5365.032146] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5365.062677] I-pipe: Domain RTAI unregistered.
[ 5365.062711] RTAI[hal]: unmounted.
